Where can a place the jack on the front and rear to lift both wheels off the ground at once? (ie both front wheels or both rear)
I've been able to lift the rear by putting the jack on the frame just behind the rear differential (if I'm remembering right). I don't know a good spot in the front. Much of it is covered by the plastic panels anyway.
D-
I'm not sure if the spot i used for my floor jack was ok :(
I also wanted to know the answer to this question. The owners manual only tells you how to jack up the car using the stock jack. The instructions also show you how to only lift it so that one wheel is off the ground.
The rear jacking point it the differential.
The front point is the center of the front cross member.
If you look a little more closely at the manual, there is a diagram of these.
