You may want to stick with a Denso sensor.
My last Bosch universal did not last very long. Just saying...
Digger08
I had the same issue as digger... I had a Bosch Univeral too and it didn't last long at all. Just a heads up...
i would not recomend buying a "universal" o2 sensor. fix it right and buy the OEM sensor or do what drunkenmonkey said.
And I would highly reconmend that you dont cut and soder a new sensor in. hacking up the OEM wire harness is the last thing you want to do and is expensive to replace.
I guess I don’t understand what’s the big deal if you cut off the old clip from the older o2 and solder it on the universal one? If it did go bad couldnt you just get an OEM one and then take out the old one. Would the new OEM have a clip
