1 - 20 of 32 Posts
My upgrades are finally finished... I picked up the car on the 23rd and have had no problems with it... Here are some details...
2001 Eshift
GT35R ball bearing turbo
Toyomoto ceramic coated manifold
Racegate
Godzilla BOV
3" downpipe (no cat)
3" PFS cat back exhaust
PFS spec. intercooler
Custom IC piping 2.5"
HKS 272 cams
HKS cam gears
GTE internals
Boost Cooler stage 2 water/alcohol injection
100 Shot nitrous (not currently used, but will be soon)
Electromotive TEC-3 standalone
PFS Built auto trans
Precision torque convertor
twin walbro fuel pumps
etc...
Daily driven setup is currently at 20 psi, 478.8 rwhp, 412.2 rwtq
93 octane with water injection (20 below fluid)
C-16 setup, 26psi, 561.4 rwhp, 554.8 rwtq
I will finish the nitrous install once a few parts arrive and I speak with Ray about timing, etc... Pics...
Reactions: VP500
Waiting for someone to ask where the water cooling hose is :rolleyes:
Nice car, I'm jealous. Holy God those are some nice numbers. Any chance you're going to any meets soon? We Floridians would love to see that car in action!
I may attend a meet if there is one nearby... I have been really busy lately with my business, hopefully I will get some time to play soon.
I now have some traction issues and am in desperate need of brakes, so I am ordering some new rotors, pads, having my back fenders rolled and hopefully I can fit some 255/35/18's in the rear on my manarays...
Diabolic Serenity said:
20psi seems high, I am not to sure if it is high for an IS300 though. So whats the reliablity with it running 20psi daily driven?
20psi with a lowered compression isn't high. Did u use to drive a Honda/Acura before?
Discussion Starter #7
I'm running water/alcohol injection... I can safely run the extra psi with no detonation... Normally a built is (GTE) with lower compression can safely run 17-18psi... With water/alcohol injection you can get 20-22psi. I can run 21 psi, no problem. Water injection is like a "band aid" for the poor octane ratings in pump gas. Not nearly as good as c-16 though. I gained 28+rwhp using this setup
you can run 18-22 psi on a Supra TT safely. I was running 18.5 psi when I had my MKIV, daily.
i dont get it..i thought our cars only used one cam gear..sorry i dunno bout this stuff...
-Aaron
niceeeee =D
Godzilla bov huh?
does that thing make all the asian people run for their life when they hear it roar?
-Aaron
Exhaust...Intake.
-Aaron
Aaron our car has two camshaft=two cam gears. Our car utilizes a VVT-i ( I standing for Intake). In turn we are only able to change cam gear for the exhaust since it does not have a solenoid for variable valve timing. Only the intake side varies, hence there is a solenoid.
Discussion Starter #14
The BOV is loud as hell... I love it. I am thinking about getting the polished horn that turbonetics makes for it, but I don't think it will fit.
Generally, you only use one cam gear for a car with stock cams or only a exhaust cam. The other gear is for vvti
I am now running a standalone, no vvti and HKS272 cams on intake and exhaust, so two cam wheels are used.
not to be an ass or anything, but i think the "i" stands for intelligence
^werd
Mr. Negative
that's excellent power from an auto man w/ that turbo. congrats and enjoy.
now your next upgrade will be a turbo that can flow some more air and you'll be good to go. gt35 is nice, but just runs out of gas fast.
1 - 20 of 32 Posts
