I have a 2002 e-shift with about 36k miles. I just started noticing a lag when shifting from 1st to 2nd gear, it never happened before. Anyone have the same problem? What are the solutions? Resetting ECU...etc?
thanks
you can take it to the dealer for an ECU flash.
or, if you want a quick fix... disconnect your battery from the car for a few minutes... that should reset the ECU and you should be ok again.
IS it as simple as an ECU reset? I dont really understand how the ECU affects the shifting, if anyone can explicate.
mine was starting to do the same thing from 2nd to 3rd. Dealer first did the ecu resets and then just ended up giving me a new trany. Gotta love the customer service Lexus provides :)
I've only had 2 incidents so far with my tranny hesitating before shifting. both times I just unplug the battery for a few minutes...and it's fine.
but then I only have 15,5xx miles, so I'll have to see if it gets worse.
Your car has numerous computer systems built into it. A computer controls the engine and transmission. The same goes for the shifting. There is a smart program in it too. It learns your driving habbits, as well as driving conditions (traffic) and shifts respectably. It even controls engine power output.
