If your accelerator pedal feels like there is slack in cable and your throttle response is diminished (and its not just the spring behind the pedal), check your throttle cable and adjust it if necessary.
As always, there is risk involved in working on your car, be careful, do not hurt yourself or your car.
What You'll Need:
10mm socket
(2) 14mm wrenches or crescent wrenches (or combination thereof, I used 2 crescent wrenches)
First you'll need to pop the hood, I didn't take a photo for this since I think you should all be able to figure this step out.
In order to get to the throttle cable, you need to take off the black engine cover with the "L" emblem on it, use a 10mm socket to do this.
Towards the back of the engine, behind the throttle body and intake manifold, you will see the throttle cable coming out of its protective sheath and then connecting to the wheel on the throttle body. The cable should have just a touch of slack in it, you do not want it to be tight and making a throttle input when you are not touching the gas pedal. In order to tighten the cable, use both wrenches on the nuts and loosen the passenger side nut, slide the cable to the driver side and re-tighten, in order to loosen the throttle cable, do the opposite, loosen the driver side nut and slide toward the passenger side.
What You'll Need:
10mm socket
