Hi All,
I have a few question that I want to ask:
I’m about to try to do with my same 2003 IS300 sportcross wagon, but I want to also keep it full interior and street legal, so I have a few questions about my future build and excuse me in advance if it rude from my side to directly write a post in your tread but I have a few questions that I need in advance before I open my bottom end start building it properly with forged stuff so here is the list with my questions:
1. Front oil pan sump vs rear oil pan sump, in terms of drifting when you accelerate and spin the tires theoretically the oil will go in the back, but when you break to weight transition the car it goes again in the front, also the front sump oil pan looks like it have smaller nose and is sucking the oil much faster because of the tighter hole right ? Or I’m wrong about it, that’s why I’m asking you guys as you may know better than me ! So please let me know which one will flow more oil and and there will be no oil hunger while drifting, my build is IS300 stock GE (fully stock GE head with stock cams springs etc.) forged pistons, rods etc. I’ll use Speeduino custom STM32 base 6 cylinder sequential one that I’ve actually created and designed on my own !
2. Do I need to choose specific pistons and rods in order the engine red line to go higher redline or this will be achievable only with higher lift cams such as BC264 or BC272, because mainly I would love to keep stock 86mm cylinder bore (only if the cylinders are in perfect condition of course and if it could stay at 86mm and not necessarily to be re-bored ! If not then it will be re-bored)
3. I’ll be swapping BMW ZF CS6-53DZ 6 speed manual (currently with stock Auto A650 one) with PMCMotors full kit dual or single heavy duty clutch, so my question about that is, how or do I need to delete Traction Control and how ? I mean that currently even TC is switched off it simply is not switched off, I start sliding and it kicks in again, may be because of the Auto Gearbox dunno ? I prefer to keep TC but only if I will be able to completely turn it off and switch it on (when needed), no idea if the manual gearbox IS300s can fully turn it off and drift with TC OFF ?
thanks in advance for your kind help in advance !
