121 - 140 of 161 Posts
That turbo is your problem dude. 7875 is a giant turbo. Surely that’s not the standard turbo they ship with their kit?
Discussion Starter #122
Honestly the XS kit has changed a lot over time, so there is no "normal kit". I think I'll wait for the different exhaust manifold and see if that fixes it. If not, retrofit.
2002 Lexus IS300
Damn. Not to hate on XS power but that manifold sucks ass. That compressor housing is very close. Also the outlet is very close to the engine bay. If you can’t even clock the turbo good luck getting a coupler on that or at least one that won’t get smashed up when reinstalling the turbo back onto the manifold and just have a permanent dent in it.
Downpipe looks like it will need some finesse. I applaud you on making progress lol. Who am I to talk. Lmao.
Discussion Starter #124
Do you mean having one made? The thing that is going to cost money is you buying all three things separately and then bringing it to them to make you a system. It might be cheaper to just buy a cat back system that will already have a resonator and muffler and all that piping done.
All you would need at that point is to buy a high flow cat and have a small section of pipe made from the down pipe to the cat back system. They will just put the cat into that small section.
I'm still mulling what the best deal would be. Really there are two options.
OPTION A) BUY YOUR OWN PIECES
(Greddy Muffler $150)
(Resonator $50)
(High Flow Cat $50)
And then pay the shop to connect the pieces with 3" pipe.
OPTION B) BUY A CATBACK
(Greddy Catback $650)
(High Flow Cat $50)
So really we have:
OPTION A) $250 + pipe and labor
vs...
OPTION B) $700 + less pipe and less labor
So the real question comes down to...
"Would the pipe & labor in option A be $450 cheaper than the pipe & labor in option B?"
Is it that simple, or are there other things to take into consideration?
2002 Lexus IS300
(Resonator $50)
(High Flow Cat $50)
(High Flow Cat $50)
So really we have:
vs...
It’s that simple. Looks like option A might be cheaper slightly however the bigger question is can the shop mandrel bend 3” pipe. Most shops can’t.
Discussion Starter #126
yes i've heard. i'm going to call around and get some quotes and let the quotes make my decision for me :p. First gotta get everything else done though :)
Thats like a 1000hp sized turbo though man.
Like i don’t know if a stock GE will spool it. Maybe I’m way off, idk.
I’m convinced that manifold is for a Supra. XS used to have a tig welded steam pipe mani that was IS300 - specific.
Discussion Starter #128
Yeah they gave me this...
137240
Instead of this..
137241
As far as the turbo size, I really don't know since I don't have much experience with other turbo setups. time will tell!
Well, I’m telling you. It’s a huge turbo.
Cast 78/75 XSP 7875 Turbo LS/LS1/L33 4.8/5.3/5.7/6.0 - 800HP Rated
Exducer: 75mm
Inducer: 82mm Turbine Wheel
Compressor: 78mm
Exducer 102mm
All that’s ^ from their eBay ad for the turbo. I’m sure it flows a ton of cfm at low boost but will a stock GE spool it? Folks use turbos even bigger on 3L but they usually have high compression pistons and E85 to spool it. Looks like they’re marketing the 7875 to the Chevy LS crowd in their eBay ad. I think I’d contact them about the turbo being correct and also the manifold. That tig steampipe mani probably cost twice as much as the one they sent you. Make them do you right dude.
Discussion Starter #131
It's an absolute headache to deal with them. At this point, I just want the nicer manifold. I can live with the turbo. and if i can't, i'll swap it out.
What would be the negative effects of a big turbo? low boost under low rpm and a lot of turbo lag?
Is that kit made for a GTE or a GE when you bought it and is it made for the IS300? The engine bay of the IS300 is a lot smaller than a GS300 or Supra making "general" 2jz-ge kits not a direct fit to the IS300 without lots of modifications to the kit. Lastly, Kris is right, that turbo is huge low boost applications. You might not even get any boost until 5k RPM which makes your powerband very small. If you are going for low boost with a usually powerband, I would go with a 5858 with a .64AR or something in that range. You should start spooling at around 2k RPM and full boost around 4-5k giving a way better powerband. One last thing I noticed about your picture is that your downpipe will not fit with the ABS lines right there. You'll need to shorten them and run along the firewall giving you more room or buy a flared ABS relocation kit.
Discussion Starter #133
should've got the cx kit. boo.
2002 Lexus IS300
Sucks to find this stuff out now as you have already put in the work. Just echoing what’s already stated. Getting that manifold replaced would be ideal. That might allow the turbo you have to clear a little better in every area. However it’s looking like a different manifold AND turbo might be necessary to get you in the ballpark.
Discussion Starter #137
Well the IC kits the same between them. If XS will swap you out the mani for the steam pipe version, and a smaller turbo, I think you’ll be good to go. At least headed in the right direction.
The turbo isn't right, the kit didn't come with intercooler piping, the exhaust manifold isn't right, the wastegate will need to be replaced, the oil feed bracket wasn't right, the oil drain hardware is not ideal, the downpipe doesn't come with a midpipe... etc. etc. etc.
Honestly im looking at this "kit" I purchased and feeling like i bought a bunch of non-fitting ebay parts and a bag of crappy hardware.
(Sorry I'm a bit stressed at the moment).
I'm going to get the manifold replaced by them and address the huge turbo later
Discussion Starter #138
they don't even include IC piping in the XS kit. I essentially paid them $400 extra for IC piing from CX racing. They ripped off the "CX" from the package and removed all of the instructions before they shipped it to me -_-
Man that sucks dude sorry you’re stressing. It ain’t worth losing sleep over. Make a plan and see it through.
See I initially was gonna go na-t in 2016, so I also bought the xs kit. It had the CX intercooler + piping, plus the steampipe mani and a 6262ish chinacharger, hks clone wastegate, and a greddy type s bov clone. It was a pretty thorough kit back then but sounds like they’ve slacked off on QA nowadays.
I wouldn’t wait to address the giant V8 turbo man. I’d have them make it right when they get you the correct manifold. Did you try closing your hood with the turbo on the manifold? If my BW isn’t clocked just right the compressor will touch the underhood heat shield and bake it.
Don't get stressed over this. Cheaper turbo kits are hit or miss on fitment....most of the time it's a miss but they are cheaper for a reason. That same kit from a name brand place like PHR or Real Street will run up to like 4k easily. Figure out all the issues, categorize them on what you can fix on your own or locally, and what needs to be fixed by XS. Work with XS (I know it's a bitch) and get things replaced to make your kit work. Turbo'ing a car is not an overnight thing usually. Take your time to make sure everything is done correctly and fits right. A piece of mind, my car was down for 7months while getting the single turbo kit installed and fitted right.
