Worked stalled due to annoying (and beautiful) ice. I'm taking this time to make some decisions, but some small things, and get ready for the last big push.
Below are some outstanding issues or decisions. Feel free to give advice on any or all of them
EXHAUST:
I have a full HKS Hi Power that's been modifed all at way to the canister for a full 3 inch. At idle it's decent, not to loud but has a deep tone. If you want something quiet, I would suggest adding a resonator but that does add restriction to the exhaust flow. I suggest buying a canister and have a shop do a custom 3inch from the downpipe back. That way, you can add in a high flow cat and a resonator if you want.
- I decided I'm going to get 3" custom exhaust from the downpipe to the muffler.
- I'm not sure which muffler or muffler&resonator combo to go with. (Would prefer a deeper exhaust note that is relatively quiet at idle)
- Not sure how I can pass VA inspection without any cats on my car though...
WASTEGATE:
- I'm not 100% sure how to connect the hose on the WG.
- Do I leave the top 2 areas (red circles) open to atmosphere and connect the port on the side (green circle) to the boost port on the turbo?
- Also I wonder if I should bolt the wastegate to the exhaust manifold BEFORE I install the exhaust manifold or AFTER. (I suppose I can just figure that one out)
The small hole at the top should have an bolt that is an Allen wrench style that blocks that off. Check the stuff that comes with your turbo kit, should be in there. The bigger bolt at the top is meant for a electronic boost control or multiple port controller to add pressure to the diagram if you want to go above spring rate boost. If you aren't using a electronic one or multiple port, VTA. Manual boost controllers usually connect to the lower green portion to control the pressure from the turbo to the wastegate to increase boost. I may not be 100% correct here because I have a 44mm Tial wastegate but assuming all wastegates works the same way.
O2 SENSORS:
When you go turbo, most likely you aren't going to use B2S2 (Bank 2 Sensor 2) or B1S2 sensors anymore (secondary sensors). You are going to retain the B1S1 Sensor in the first bung and I'm not either sure about the B2S1 but you can probably use the 2nd bung for that. The lowest O2 bung on the downpipe is for your wideband sensor.
- It seems like I won't have enough bungs to install all of my o2 sensors AND my wideband
- I pulled 3 o2 sensors out of my stock headers. The new turbo downpipe only has 3 bungs. It seems like I'd need 4 bungs to add the 3 o2 sensors back AND my wideband (3+1)
- I'm not sure how to handle that. Install another bung on the downpipe? Can I just leave an o2 sensor unbolted?
INTERCOOLER PIPING:
I have the CX intercooler kit. It looks like I'll have to do some cutting. (behind p/s headlight //// intercooler bracket //// MAYBE by the d/s fender.)
I've seen people drill a hole behind the passenger headlight to run the piping through there. I personally had the IC piping ran next to the wall then angle out so I didn't have to drill.
OIL FEED:
The turbo kit did not come with a proper oil feed fitting for the top of the turbo. Had to order one off amazon (12 bucks)
OIL RETURN:
The fitting on the turbo looks like it's going to be VERY close to the exhaust manifold. It's a high temp rubber hose. I'm worried about it burning up against the manifold.
Get a high quality and high temp stainless steel one....rubber one is sketchy running that close, cold melt. Replace the cheap stuff now before it cause you tons of problem later.
GAUGES:
I purchased an AEM Wideband & Boost gauge. About $200.
Plan on installing in the cubby above the radio where the NAV goes.
When I need to get power to the gauges, do I just tap into the power wire to my cigarette lighter or something? Is there an easier way to get power?
You can wire it to your ignition for power when you turn the car on or wire it to your radio power. Either way is acceptable.
--- Hopefully the snow will melt soon. I'm off all next week (between jobs)---
