Is there currently a kit i can get to get the rev limit up? or how might one get their displacement up??
to get the rev limiter up you will have to add the Greddy E-manage Ultimate and tune it... or go with a standalone... the only two way i know
wouldn't there be any internal part i would need to replace for the added pressure? like head studs?
to safely increase the rpm limit any any motor your gonna have to take the head apart and change the valves and valve springs, otherwise you may end up with a costly repair bill when that spring breaks and drops that valve into a piston, its also wise to change cams when your upping the rpm range, cause otherwise your not gonna gain much if any power from just increasing the capabilities to go higher in the rpm range.
just a heads up, as for adding displacement, there are stroker kits available, from who i don't recall atm.
people have been safely revving to 7200 rpm and even 7500 rpm, even on boost. above that, you need some valvetrain work.
