41 - 60 of 112 Posts
Discussion Starter #41
Updated
See original Post
If anyone knows an easy way on how I can keep the spacing between
the columns, that would be great. When I look at it in edit mode its all
nicely spaced out, but when I hit save it 'scrunches' it all together.
Thanks!
the forum removes all the spaces and stuff for some reason, maybe a mod can chime in
hey, can anyone help me out on the name of this part number
Its label right next to the O ring, 82125A and 91611-B0616
Any help would be great, Thanks in advance
82125A, wouldn't be a valid part number. As for the 916 number, it's going to be hard to back track what the o-ring is for. Are you looking for a specific part (o-ring)?
well i just got my new vss that i order from my lexus dealer ship, and they gave me this sheet too. I'm curious what that part is..Heres two snap shots. The # i asked for is right next to the o ring(96721-24018), once again the part im trying to figure out is the 82125A# and the 91611#
Im looking for a part number for the oil filter for the Altezza AS200 GXE10 - 1G-FE Inline 6, 2.0 L (I assuming its the same one in the parts sheet), also the serp belt and timing belt.
Also for the 3SGE engine, can I get a serp belt number
Number for lowering springs
Bless
Discussion Starter #48
Added a few things:
PCV Grommet ---- 90480-18001 4.40 Available at Toyota Dealers
idler pulley ------- 13505-46041 80.54 Available at Toyota Dealers
timing tensioner -- 13540-46030 68.53 Available at Toyota Dealers
Serepentine Ten - 16620-0W025 186.31 Available at Toyota Dealers
Upper Rad Hose -- 16571-46310 xx.xx --- Lexus Only
Lower Rad Hose -- 16572-46290 xx.xx --- Lexus Only
A few parts to add to the list
13753-74110 - 2.750mm(1.083") Valve Shim
90311-40001 - Automatic Trans-Extension Housing Seal
16325-46010 - No.1 Water Bypass Pipe Gasket
90311-38032 - Manual Trans- Extension Housing Seal
anyone know the part number for the intake gasket, this is the one between the lower runner and the cylinder head.
Discussion Starter #54
Anyone have the part number for the front under cover panel bolts ?
90159-60323........Undercover Bolts......$.83....15 Total
90080-15090........Front Bumper Bolts...$3.88....4 Total
90467-07121-C0...Front Bumper Clips....$1.14....4 Total
Can u tell I'm bored at work today? LOL
nautox, I need your help bro! I called a few dealership and they can't help me out. When I pulled my motor out, I damaged/broke a few connectors on the main engine harness. I was told that I can't buy just the connector ends, I have to buy the entire harness, which is kinda lame in my opinion because you can easily repin em.
I am looking for the following connectors:
1. From the main engine harness to the powersteering pump pressure sensor.
2. Brake Reservior fluid level sensor.
3. From main engine harness- to the transmission. This is the main connector that connects to the wiring that goes internally to the solenoids. It's the second to last from the rear of the transmission on the driver side.
Please tell me you can get it! I do not want to buy a new harness.
I gotta let everyone know Rob (Nautox) is a great guy. He is a definitely an asset to this forum. I PMed him wit my cry for help, less than 24 hrs later he hit me back up with concrete info. He even took the time to hit me up with diagrams of the parts.
I went to three different dealerships and they all told me I had to buy a whole entire harness! Rob saved me money!
Discussion Starter #57
Thanks Eminence, I'm going to post the info that we talked about for everyone else...
BTW ANY Lexus or Toyota Dealer should have the ability to go into
TIS and look up wiring connectors in the online repair manuals for Scion, Toyota and Lexus. We can look up Owner Manuals too and print just about anything from the Repair to the Electrical schematics. Some of the 90's stuff isn't alway online, but anything 2000 and newer is in there.
P2 Power Steering Pressure Sensor
90980-10845 $6.60 Connector
82998-12440 $5.60 Wires x3
B1 Brake Fluid Reservoir Level Switch
90980-11207 $60.14 Connector
82998-12440 $5.60 Wires x2
E1 ECT Solonoid
90980-11151 $9.09 Connector
82998-12440 $5.60 Wires x12
P1 Neutral Park/Safety Switch
90980-11784 $10.63 Connector
82998-12480 $5.60 Wires x2
82998-12440 $5.60 Wires x7
V9 Speed Sensor (Speedometer/Dash)
90980-11143 $7.06 Connector
V1 Speed Sensor (Transmission)
90980-11156 $6.17 Connector
O1 Speed Sensor (Overdrive)
B9 Back Up / Reverse Switch
90980-11142 $3.57 Connector
Note: some connectors have a 5 digit number stamped on them. All you
have to do is add 90980- to the front of that and you have the
part number.
if we can't get an Air Filter, does that mean we're forced to have it replaced at a dealership?
Have you guys changed your own air filters? If so, what filter did you use and where did you get it?
I replaced my air filter and cabin filter recently.. got them both from here;
Each filter is under ten bucks and so is shippin).
Hope this helps!
Air Filter Lexus GS300 IS300 IS GS 300 2JZGE Cleaner $7.95
Cabin Air Filter Lexus IS300 RX300 Toyota Highlander $9.99
Shipping to my zip (1 pkg x 3 lbs total) (Ground) $8.90
Total; $26.84 for both.
and let me just say WOW was my cabin filter dirty... it was easy to change tho.
I'm considering doing it again just to take photos for a new DIY thread but may not be all that helpful..?
Japanese only parts have their own little toyota part number. Even if you can get the part number, U.S Dealer wouldnt be able to find it in their database.
