Status
Not open for further replies.
Exclusive Agent
(no particular order yet)
If you have some DIY threads that are bookmarked somewhere that you don't see on this list, PM me and I'll add them. Don't be shy.
http://my.is/forums/f87/diy-installing-switch-near-steering-wheel-383577/
http://my.is/forums/f87/transmission-tranny-drain-refill-flush-diy-pics-included-printable-pdf-attached-254631/
http://my.is/forums/f88/diy-cam-gear-install-383203/
http://my.is/forums/f87/diy-timing-belt-water-pump-348511/
http://my.is/forums/f114/jefftsais-diy-videos-servicing-2jz-376609/
http://my.is/forums/f90/diy-info-black-headlight-mod-one-pics-285707/
http://my.is/forums/f90/diy-caliper-painting-w-decals-353126/
http://my.is/forums/f89/brake-pad-rotor-replacement-diy-lots-pics-pdf-instructions-now-attached-255699/
http://my.is/forums/f103/diy-front-speaker-replacement-381740/
http://my.is/forums/f90/diy-dark-chrome-emblem-painting-358344/
http://my.is/forums/f90/diy-dashboard-fix-melting-dash-look-374628/
http://my.is/forums/f90/diy-led-clear-courtesy-light-332431/
http://my.is/forums/f87/oil-change-diy-lots-pics-printable-pdf-attached-264598/
http://my.is/forums/f90/diy-key-reprogramming-334593/
http://my.is/forums/f90/custom-sidemarkers-diy-257028/
http://my.is/forums/f87/power-steering-fluid-flush-diy-w-lots-pics-256159/
http://my.is/forums/f90/diy-convert-your-guage-cluster-lights-white-free-366356/
http://my.is/forums/f89/diy-coil-spring-installation-instructions-286698/
http://my.is/forums/f87/60k-service-diy-information-procedures-256162/
http://my.is/forums/f138/diy-cabin-air-filter-tutorial-pdf-341935/
http://my.is/forums/f90/diy-removing-front-bumper-headlights-lots-pics-video-354876/
http://my.is/forums/f87/radiator-drain-refill-diy-pictures-256156/
http://my.is/forums/f114/diy-how-rebuild-2jz-368453/
http://my.is/forums/f90/tutorial-diy-superstar-led-bulbs-main-gauge-cluster-291397/
http://my.is/forums/f87/differential-diff-fluid-replacement-diy-lots-pics-printable-pdf-attached-254397/
http://my.is/forums/f90/diy-door-chime-switch-370246/
http://my.is/forums/f89/diy-alignment-351650/
http://my.is/forums/f90/diy-high-mount-brake-light-non-spoiler-288223/
http://my.is/forums/f87/diy-brake-fluid-replacement-281014/
http://my.is/forums/f90/diy-tutorial-how-relocate-oil-filter-332140/
http://my.is/forums/f88/clutch-swap-diy-350510/
http://my.is/forums/f90/diy-how-remove-navigation-screen-dash-completed-357746/
http://my.is/forums/f90/diy-inner-trunk-light-removal-tutorial-pics-354866/
http://my.is/forums/f88/diy-header-install-352602/
http://my.is/forums/f90/diy-installing-jdm-dash-tray-pics-343197/
http://my.is/forums/f90/relocating-horns-mod-aftermarket-grills-pics-finally-156559/
http://my.is/forums/f68/is300-rear-bumper-removal-341081/
http://my.is/forums/f63/is300-entire-system-overhaul-341089/
http://my.is/forums/f103/what-best-tactic-completely-removing-stock-amp-303399/
http://my.is/forums/f90/how-change-license-lights-tutorial-inside-174186/
http://my.is/forums/f103/diy-grounding-kit-40-install-347905/
http://my.is/forums/f62/is300-throttle-cable-spacer-350180/
http://www.isfanatics.com/forums/forumdisplay.php?f=80&order=desc
http://my.is/forums/f87/coolant-flush-block-question-377893/
http://my.is/forums/f103/because-other-pre-outs-thread-failed-384968/
Here are a few more. Some might be duplicates:
Brake Pad
Tranny Fluid
Oil Change
Power Steering Fluid
Spark Plugs
http://my.is/forums/f87/spark-plug-replacement-diy-lots-pics-printable-pdf-attached-254217/
60k Service
http://my.is/forums/f53/how-stand-alone-fog-lights-mod-106666/
http://my.is/forums/f53/install-jdm-black-tail-lights-106668/
http://my.is/forums/f53/suspension-arms-install-guide-online-version-354708/
http://my.is/forums/f53/install-clear-corner-lenses-106661/
http://my.is/forums/f53/how-fog-lamps-high-beams-271429/
http://my.is/forums/f53/how-keep-45-sec-moonroof-driver-window-open-close-delay-if-any-door-opened-248114/
http://my.is/forums/f53/install-jdm-dash-tray-106662/
http://my.is/forums/f53/install-jic-strut-tower-bar-106664/
http://my.is/forums/f53/install-pro-lex-gii-short-shift-kit-106669/
http://my.is/forums/f53/install-delphi-skyfi-fm-modulator-106667/
http://my.is/forums/f53/install-rear-section-exhaust-hks-hiper-106665/
http://my.is/forums/f53/install-trd-race-sway-bars-106663/
http://my.is/forums/f90/diy-key-reprogramming-334593/?highlight=DIY
http://my.is/forums/f138/diy-cabin-air-filter-tutorial-pdf-341935/?highlight=DIY
http://my.is/forums/f87/diy-brake-fluid-replacement-281014/?highlight=DIY
http://my.is/forums/f88/clutch-swap-diy-350510/?highlight=DIY
http://my.is/forums/f115/diy-actuator-install-tips-regulator-install-388787/
Fuel Pump Install:
http://my.is/forums/f114/diy-walbro-255-fuel-pump-install-pics-alot-409785/
This is another thread full of DIYs:
http://my.is/forums/f90/tutorial-thread-diy-ers-226270/
Status
