1 - 9 of 9 Posts
Thanks to my.is member lextasyis300 for this excellent tutorial.
Well, the last engine bay cleaning how-to was great, but the pics dont work anymore, so I decided to do one myself. PLEASE don't compare too much, as I am no professional at this, but I have done it enough to kinda know what Im doin. (The pictures are not great, but you can get a good idea)
Supplies Needed:
1. Engine Degreaser
2. Purple Power
3. Scissors
4. 2 or 3 Large Trash Bags
5. Packing Tape
6. Mother's Back-to-Black (or another plastic polisher) (not pictured)
I like to used the cheap Advance Auto brand Engine Degreaser, but Engine Brite is another choice. I also like to use Purple Power for a little extra degreasing.
My Dirty Engine Bay, not horrible because I do this 4 times a year, but still very disgraceful:
Step One: Taping Off
This is not hard, but it is rather time consuming because you want to do it right. I used blue painters tape to help mark some of the harder to see parts that should be covered. Pretty much any where that there are electrical connections, plugs, etc. You also need to tape off the Power Steering and Break Resoviors, MAF Sensor, and Battery Terminals. You also want to tape off the two O2 sensors that you can see from the top. If you have an aftermarket intake, you can either cover the filter or take it off and put some plastic over the open tube (this is also a good time to clean and oil your filter as it will give it plenty of time to dry, which is what I did).
Step Two: Squirting Down with Engine Degreaser
This is easy, pretty much you want to hose down everything with the engine degreaser. You especially want to make sure you get in good where the headers bolt on, as seen in the second picture. I use a full can of the degreaser and a few squirts from the Purple Power on all the black covers to get the extra clean. I let this sit for 10-15 minutes, I use this time to clean my K&N filter.
Step Three: Washing Off the Degreaser
This step can be a little tricky, but its not hard. You want to make sure that you get all or as much as possible of the degreaser off. I start at the top, the engine cover, and work down. Again, make sure you squirt really well where the headers bolt on. If you are on concrete, you will see the water running out has a multicolor look, this is a good guide as to whether or not you need to keep hosing it off. I also make sure there is no degreaser left sitting on the underbody panel, so squirt real well on both sides of the motor to get it all off. You could probably take the panel off, but that seemed like a lot of work at the time
Step Four: Engine Drying/Removing Plastic and Tape
This is another easy step, just take all the plastic and tape off and let the engine dry for 15 minutes or so. Wipe off the main covers so that no water spots dry on there
Step Five: Burn Off the Rest of the Water/Degreaser
Now just start the engine and let it run for 10-15 minutes. You may or may not see smoke at this time, I usually don't until I have been driving around for 10 minutes and the motor gets REALLY hot.
Step Six: Shine Up The Plastic
This is where the Mother's Back-to-Black comes in. I always take all the covers off to let them cool, and it also makes it WAY easier to shine and polish them up. I dont have a picture of this step because I forgot, but you know how the covers look. I circled all the covers that I take off in this picture
Step 7: Put Covers and Filter Back On
This is a crucial step ;)
Step 8: Step Back and Admire the View
My After Pics (and yes they are dry to the touch):
This took me roughly an hour to and hour and a half, for a first timer I would allow yourself atleast 2.5 hours to be sure you get it right. Any questions, just post them up or PM me (yes I did a little something extra to get the covers to shine that much, but I'm not quite ready to give up that secret yet, but its not too hard to figure out :p).
Disclaimer: These are my personal methods/tecniques and I cannot and will not be held responsible for any misuses or problems that one may encounter while doing this cleaning. Thank You
Hey, do you think next time when you clean your engine you can post some more pictures of taping it off at different angles?
Thanks!
Be careful spraying off the actual engine!!! Our detail guys (Lexus dealership) spray down the engine bay and when they do, it's happened numerous times (on the 2JZ motor) where water has gone down into the spark plug valley and caused misfires (tons of them), even with the covers on...be very careful when you're spraying it off...
^^^ Exactly.. i prefer trash bag over battery, alternator, and filter.
I'm engine is pretty dusty but I'm too nervous to spray it after reading this.
I would have thought the cover would have been enough protection.
Any suggestions on angles not to spray from?
If you have the time for it, it's probably safer if you use a squirt bottle + a rag and bucket. I mean, it'll definitely take longer... but there's a lot less water flying around everywhere and you clean exactly what you intend to.
I'm WAY overdue for this, by about 5 years :lol:. But actually, it doesn't look terrible. The best way is to not cover anything, and use a very powerful pressure washer to get really close to the plugs. J/k, please DO NOT do that, but thanks for reminding me what needs to be covered. I have battery acid powder in the tray, so I'll take out the battery.
I also want to remove the engine cover. Would it be stupid to get water by the plugs (with LOW pressure garden hose, ofc)? And are there other wires that should be covered?
Besides these precautions, I intend to use my "canned air" type blower, then use my 5 yr old can of CD2 Engine Detailer (awesome stuff, back then). Any reason not to use either of these?
1 - 9 of 9 Posts
