1 - 16 of 16 Posts
I saw a tundra with swutchback drl/blinkers last week, and decided that my car would look good with drls. I know that some is300 have the hi beam drl, however mind does not, whether it was deleted or never came factory that way.
So I ordered some VLEDS v6 Triton switchbacks. Expensive, but quality bulbs and very bright.
I also decided that I wanted them to operate like my old Volkswagen, drl on with park brake off/drl off with park brake engaged since it's a manual transmission. This will require a relay, and wiring to the park brake switch (which I had already done while installing my remote start)
That brings the next issue.
Front turn signal bulbs on these cars are 7440 (single filament) and will require 7443 harness/sockets which is dual filament as to add the drl function.
As I'm still waiting on the harnesses, I installed the wiring and relay last night
IMG_20190110_165649018_1547234640790.jpg IMG_20190110_165659220_1547234666023.jpg
Used an add a fuse from the local auto parts store for a key on power source. I used the engine fuse box, but in hindsight an interior fuse might have been a better bet, just would have to mount the relay inside.
Used a Dremel to clear the way for wiring to come out of the fuse block, so the cap is still functional.
Then I wired my relay trigger to the park brake wire I had previously wired up.
These connections are all soldered mind you, I don't recommend butt connectors or spade terminals, especially not quick splice connectors.
Then I trimmed all the extra wiring up since I built the relay before installing into the car, and wrapped it up nicely. I did find there's a perfect spot next to the battery with a bolt hole to mount my relay.
Now I am just waiting on my harnesses to come in so I can install the bulbs and finish up. Will update in a day or two.
If anyone was curious on how I wired the relay..
Mr. Roo
Ah nice, so did you replace all 4 signals with the Tritons?
Glad to see I'm not the only person doing this
Mine are the V3s though, and I wired them up to a switch on the dash, to the ACC power, so they only get power when the key is turned. I also used the stock 7440 connector harness, I just cut out the extra wire for the white LEDs and put them straight to the switch. Post pics of the results. I'm thinking of changing to the V6s
Ahhhh yes, I'm super glad you included a picture. They look good.
Yes, all 4 are going to be the tritons (pricey as shit)
Hoping to get it done this weekend, got home to harnesses in the mail today, my other pair of bulbs will be here tomorrow.
Switchback is an led bulb, that operate as a daytime running light, as well as a turn signal. Meaning they're drl while I'm driving, but when I hit the blinker, the white light flips off to use the Amber turn, and when the turn signal is done the white light comes back on.
Mr. Roo
haha yeah they are pricey, but totally worth it. When I got mine, it was many years ago when they were MUCH cheaper, and I think they had a 35% off sale. I've been able to actually warranty them all the up to the latest version of the V3, because when one bulb or controller would fail, I needed all 4 to match and they'd just send them all lol. They work great, but the V6 is supposed to be brighter I supposedly, and of course, they are much smaller with WAY fewer wiring. Let me know how you like them! I have a regular amber triton V3 in the back signal, but I do want to do 4 switchbacks back there for dual signal/reverse. 8 pairs total lol... ouch on the $$$
Good work guys. I put switchbacks in one of my cars. But I added another wire that ties to the power for the HID's. So they are white with the headlights on. Then turn amber when you use the turn signals. I changed the plugs them self. Then used a 7443 style. I also did a similar mod to the rear. If I ever get time. I was thinking of looking at the factory DRL circuit and trying to figure out where the signal comes in.
Discussion Starter #8
Update, installed and wired everything. Blinkers work great and are bright as all hell. But my drl circuit is blowing fuses.
I have ground at the output for the drl circuit when checking with a power probe. I think I might have garbage light sockets. Will need to look into it further when I get time. Will update then.
Discussion Starter #9
I was thinking about the switchbacks in the rear for dual signals and reverse. But there's little room behind the tail lights in these cars. Unsure what I would do with all of the extra wiring.
I also want to get the full led tail lights. I think the all red would look better than the altezzas. But that's money I don't need to spend at the moment.
Mr. Roo
yeah there's not much room behind the lights, but the V6 don't have all that extra wiring. I did have to hammer the sheet metal real good though to fit regular V3s in there, but the V6 are supposedly smaller.
As for the shorting issue. I think maybe the parking brake is a ground, not a hot? that doesn't really make much sense though. Did you get CK sockets, or CK bulbs? They are different. Also maybe try one bulb at a time, one of them could be bad
Discussion Starter #12 (Edited)
The circuit is bad without bulbs even installed. But the turn signal circuits work flawlessly. So I'm going to order sockets from Napa or some pigtails straight from Toyota (I work here and get parts at cost) and do it that way. Unsure about the whole ck/non ck thing. That's confused me. But I'm doubtful that's the issue, apparently those bulbs work the same regardless.
Edit: also yes, park brake switch provides ground. The ground at the park brake switch is the trigger for the relay I wired. Nothing more. When no ground is seen at the relay, power is sent out to the bulbs. When ground is present, it sends no power.
Discussion Starter #14
Sounds like you got it figured out then. If the new sockets don't work, I'd just leave the wiring stock and pull out the white wire and do it separately
That's the plan. Only think I don't like about your method, is if there ever was reason to warranty these, I doubt they'd take them with the harness cut apart.
Sent from my Moto Z (2) using Tapatalk
Mr. Roo
lol, the way they would warranty my stuff was by having me destroy it and send them a picture. Cutting the wires was their recommended method.
Discussion Starter #16
Finally got it figured out yesterday, apart from a slight warranty issue, everything is operating perfectly.
My dumbass had the sockets wired incorrectly. Never assume black is ground.
Everything is working perfectly now however, and it looks great.
The one needs to be warrantied, as the drl functions but the turn signal does not. But I'm not too terribly upset at this moment.
1 - 16 of 16 Posts
