I am having problems on the door locks. The doors lock but not unlock. How exactly did you wire the 2 relays. Can anybody help me out with this? Thanks.
Useless
Just grab the - trigger wires located in either kick panel.
is300 door locks
by the way i'm doing an alarm(viper 791xv) install for it.
Got to simulate driver lock unlocking. Another alternative is to PM Lisnup65 for a different solution.
Useless
The industry standard and recommended way is available here: http://my.is/forums/showthread.php?p=1653598#post1653598
My way uses a Green/Red and Green/Black located in either kick panel harness going into the door. A simple negative pulse is required and will operate the door locks just fine. The only issue I have ever had is if the factory alarm does go off, you must unlock with factory remote before aftermarket system will be allowed to operate the locks again. Not a biggy as the factory remote is located on your key!
