1 - 15 of 15 Posts
Super Moderator
Here it is! This is the 1326 page 14.4Mb Diagnostic Manual. This is not the FSM, which is already available, but just the DI section of it, which is not included in any other link and hasn't been available until now. It includes complete, easy to read troubleshooting for all major systems on all years of the IS300. It also contains part numbers(for parts and SST's), the complete wiring schematics and electrical troubleshooting, TSB's, and much much more. It also contains all major codes(DTC's), the definition of them, and an easy guide on how to repair the fault(s). It's the same manual Lexus uses and I constantly reference it when helping out on here.
Comments appreciated if it helps you out! Thanks and Enjoy!
https://www.dropbox.com/s/nji5xr398lz7mio/2001-05 IS300 Diagnostic & Wiring & TSB Manual.pdf?dl=0
Here's more info on the connectors in the ECM.
http://my.is/forums/f87/ecu-body-harness-plug-pinout-470945/#post7002209
Super Moderator
Discussion Starter #6 (Edited)
You're welcome. It's been up for a bit but not many folks in these forums may have seen it. When it comes down to needing a code completely explained or needing a wiring diagram, it has it all. Download it while you can, but it should be a good link for awhile though. I already see it's getting much more attention here then it did in the other forum.
Super Moderator
Discussion Starter #10 (Edited)
Do we know how to unsecure the file so I can make bookmarks?
I'm not positive how to do that Wing, otherwise if you know what i can do i will. Bookmarks would be badass, although i have most of em in my head already:lol:
Edit: I made another public link so i don't know if this will help any better besides copying it and bookmarking it the hard way.
http://db.tt/6fjczNnm
Well if I was able to root and install Jelly Bean on my Galaxy S3 at the store while the guy was ringing me up...LOL, this shouldn't be too difficult to get around :approve. I'll let you know if I'm able to "fix" it so you can update you link.
Well that was easy....document has been stripped of security.
Jason, I'm going to start working on adding bookmarks. I will say the filesize increased...A SHIT LOAD MORE haha...but I'll see if I can compress it then I can hand it over to you so you can replace the file you are hosting. :cool:
Super Moderator
Discussion Starter #13
Awesome. Lemme know bro and thanks!
1 - 15 of 15 Posts
