IS300
Engine Code: 2JZ-GE (w/ VVT-I)
Compression Ratio: 10.5:1
Peak Flywheel HP: 215 @ 5800 RPM
Peak Flywheel TQ: 218 @ 3800 RPM
Engine Bore: 86mm (3.39 in)
Enigne Stroke: 86mm (3.39 in)
Engine Displacement: 3.0 Liters (182.9 ci)
Curb Weight: 3,255lbs (Manual Trans) 3,270lbs (Auto Trans)
3,410lbs (Sport Cross)
Manual Trans Code: W55 (5spd)
Gear Ratios
1st: 3.566
2nd: 2.056
3rd: 1.384
4th: 1.000
5th: 0.850
Finial Drive: 3.727
Transmission and Differential Options
1993-1998 US Supra Turbo
Manual Trans Code: V160 (6spd)
Gear Ratios
1st: 3.827
2nd: 2.360
3rd: 1.685
4th: 1.312
5th: 1.000
6th: 0.793
Finial Drive: 3.133
1998-2001 JDM Supra Turbo
Manual Trans Code: V161 (6spd)
Gear Ratios
1st: 3.724
2nd: 2.246
3rd: 1.541
4th: 1.205
5ht: 1.000
6th: 0.818
Finial Drive: 3.27 or 3.24 (I searched and found both so I posted both)
1986.5-1992 US Supra Turbo
Manual Trans Code: R154 (5spd)
Gear Ratios
1st: 3.300
2nd: 1.950
3rd: 1.340
4th: 1.000
5th: 0.753
Finial Drive: 3.727
1986.5-1998 US Supra Non Turbo
Manual Trans Code: W58 (5spd)
Gear Ratios
1st: 3.285
2nd: 1.894
3rd: 1.275
4th: 1.000
5th: 0.783
Finial Drive: 4.272 (93-98) 4.300 (86.5-92)
Lexus GS430 Differential
Finial Drive Ratio: 3.27
IS300 Auto Trans Differential
Finial Drive Ratio: 3.91
1993-1998 Supra Turbo Auto Trans Differential
Finial Drive Ratio: 3.769
Engine Options
Engine Code: 2JZ-GTE (w/ or w/o VVT-I)
Compression Ratio: 8.5:1
Peak Flywheel HP: 320 @ 5600 RPM
Peak Flywheel TQ: 315 @ 4000 RPM
I'm not going to write any prices. That sorta stuff has too many variables. I gathered these numbers so others wouldn't have to search for hours just to do a simple comparisson. Feel free to post how much you paid for your swaps and who did them. Add more to this thread if you feel the need. Links to other threads would be great.
Gear Ratios
1st: 3.566
2nd: 2.056
3rd: 1.384
4th: 1.000
5th: 0.850
Finial Drive: 3.727
Gear Ratios
1st: 3.827
2nd: 2.360
3rd: 1.685
4th: 1.312
5th: 1.000
6th: 0.793
Finial Drive: 3.133
Gear Ratios
1st: 3.724
2nd: 2.246
3rd: 1.541
4th: 1.205
5ht: 1.000
6th: 0.818
Gear Ratios
1st: 3.300
2nd: 1.950
3rd: 1.340
4th: 1.000
5th: 0.753
Finial Drive: 3.727
Gear Ratios
1st: 3.285
2nd: 1.894
3rd: 1.275
4th: 1.000
5th: 0.783
Engine Options
