2002 Lexus IS 300
I recently purchased a used Altezza wing that was imported from Japan.
Unfortunately it didn't come with any hardware, and my search for info on it has come up empty.
Does anyone know what "hardware" I'm going to need to mount this wing?
Something I can just buy at a Home Depot or am I going to need to search for specific Toyota hardware online?
Thanks!
138351
2001 IS300 "Faketezza"
BLUF: Toyota used 3 ways of mounting: 2x L-brackets w/cover plates, 2x studs with 10mm nut, and 3M double sided tape.
You'll need 2 L-shaped brackets that go in the divets of the wing (mounting spot circled in red).
Where the single hole is, there usually is a stud there. If you can source the 2 L-brackets and 2x 10mm short bolts, you can mount this wing. I should add that the bracket will rivet to the trunk, but if you prefer nut and bolt I'm sure there's a work-around.
If you'd like, I can get photos of the brackets tomorrow for you as well so you'll know what to look for when sourcing. Hope this helps!
138430
