Thanks to my.is member Hiroshima for this write-up on the 60k mile maintenance.
For those who want to do most of the 60k service on your own, I have created this thread and the attached links so that you can pick and choose what you want to do. I tried to document as closely as possible the procedures taken in each procedure. I have also tried to document prices, part numbers, time taken, and effort required.
General consensus says that you do the following things:
Coolant Replacement
<l>Skill Level: Beginner</l>
Tools Needed: Minimal
http://my.is/forums/f67/is300-coolant-drain-refill-340999/
Power Steering Flush
Skill Level: Moderate
http://my.is/forums/f67/is300-power-steering-flush-340996/
Transmission Fluid Replacement
http://my.is/forums/f65/is300-auto-transmission-drain-refill-flush-340994/
Differential Fluid Replacement
http://my.is/forums/f67/is300-differential-oil-replacement-341001/
Inspect Brake Pads (Replace if necessary, 1mm is the minimum pad thickness before replacement)
Tools Needed: Moderate
http://my.is/forums/f67/is300-brake-pad-rotor-replacement-341008/
Brake Fluid Replacement
StopTech : Balanced Brake Upgrades
http://my.is/forums/f67/is300-brake-fluid-replacement-bleed-340997/
For the IS you need a 10mm wrench and a 12-14" length of 1/4" clear tubing
Spark Plug Replacement (if you have Platinum and not iridium plugs)
http://my.is/forums/f67/is300-changing-spark-plugs-340989/
Fuel System Maintenance
I use BG44k before I change the oil which is a total fuel system cleaner.
Replace PCV Valve
Replace Oil and Filter
Replace Air Filter
Replace AC Cabin Filter
Lubricate hinges
Rotate Wheels
Inspect/Replace Serpentine belt. For some reason I could not get the pulley to move so I am going to pay someone to do this for me. I know,.... it is supposed to be easy, but I was not able to do this one.
Things you probably cannot do on your own
Balance Tires (Subjective, if you need it, do it. If not I would skip it and wait until you replace your tires)
Alignment (Subjective, if you need it, do it. If not I would skip it and wait until you replace your tires)
Torque drive shaft bolts
Common Questions:
Q: How much does the dealer charge?
A: Based on everything I have ever read on this car, the 60k costs between $800-$1200 at a Lexus Dealer and $500-$700 at a Toyota dealer (if you can find one that will work on a Lexus)
Q: How much will a DIY cost, what do I have to buy, where did you get it?
A:Item Description * Cost * Purchased From
(1) Gal Coolant PN 00272-1LLAC-01 * 15.95 * Toyota
(6) Spark Plugs * 71.70 * Spark plug, Spark plug wire, spark plug gap, spark plug cross reference and ignition wires at Sparkplugs.com
(2) Qt Mobil 1 Synthetic 75/90 GL-5 rated * 19.70 * Local Auto Parts Store
(3) Toyota Type IV Tranny Fluid (Drain Refill) * 11.25 * Toyota
or
(10) Toyota Type IV Tranny Fluid (Flush) * 37.50 * Toyota
(1)Transmission Drain Crush Wash PN: 35178-30010 * 1.80 * Lexus
(2) Differential Drain/Fill Crush Wash PN: 12157-10010 * 1.68 * Lexus
(2) Qt Valvoline Dextron III ATF * 2.49 * Local Auto Parts Store
Accessory Serpentine Belt PN 99366-D1930 * 36.95 * Lexus
(6) Qts Mobil 1 Synthetic 5/30 * 24.95 * Costco
(1) Oil Filter * 6.95 * Lexus or Auto Parts and accessories for Toyota BMW Lexus and Honda irontoad.com (cheaper @ irontoad but I found out too late)
(1) Can BG 44K * 18.95 * Acura Dealer (Purchased a while ago can't remember if the cost is exact)
(1) Bottle Valvoline SynPower Brake Fluid * 8.95 * Local Auto Parts Store
(1) PCV Valve * ??.?? * Lexus (Did not replace it)
Apx Total Cost (with a tranny flush) inc. Sales Tax @ 7.75% $300.00
Add cost for AC Filter, OEM Air Filter, Alignment, Balance if necessary (I did not need them)
Balance generally $7 per wheel
Hunter Laser 4-Wheel Alignment generally $69.00
AC Filter $16.32 @ Auto Parts and accessories for Toyota BMW Lexus and Honda irontoad.com
OEM Air Filter $12.74 @ Auto Parts and accessories for Toyota BMW Lexus and Honda irontoad.com
LMK if there are any questions, I would be happy to try to answer them.
If you have any suggestions on how to make this thread better or if any of my procedures are incorrect please do post, I would be happy to make adjustments.
Thanks.
I'm ready to do my 60k, but...
Has SynPower Brake Fluid been discontinued?
Yes. SynPower Brake Fluid has been replaced by Valvoline Full Synthetic DOT 3 & DOT 4 Brake Fluid.
Is it OKAY to use the new DOT 3 & DOT 4 replacement? or is there a better recommendation for brake fluid? thx
any DOT 3/4 fluid will be fine.
Can someone give me the Lexus IS300 Brake Pad part number? I have some brake pads from my 98 Lexus ES300 and I wanted to see if they were the same.
Also... do you usually change your rotors at 60k?
Maybe this has been addressed before? On the "Spark Plug Replacement" heading, I'm assuming only platinum plugs need replacing at 60K? When do iriduim plugs need to be replaced? I spoke with a Toyota parts guy and he says that only platinums need to be replaced at 60K and iriduims at 90K. Can someone confirm this? Thanks!
Transmission filter?
Should I be changing the transmission filter with the 60k service? If I don't have to, I'd rather not, but it seems kind of counterproductive to change the fluid and not change the filter. Any advice?
