101 - 120 of 168 Posts
Discussion Starter · #101 ·
Apparently the car had a 1.6mm gasket. That’s not right I ordered it from Real Street unless they packed the wrong size mm!!
So two things gave the car a low comp, 1.6mm hg and a none shaved GE head. They bored out 30thou, now it’s sitting at 9:1:1.
GTE pistons and rods.
Discussion Starter · #102 ·
I’m going to have a go at it with the AF but I’m definitely keeping my BW. I want to run the car with the BW via “another” tuner just to see which turbo makes more power low end and top end and how early the response will be .
I gotta get the Ai Surge tank with 2x 460 walbros, i already have a 460 in the tank so I’ll have 3x 460s after the surge tank is installed.
Sent from my iPhone using Tapatalk
Discussion Starter · #104 ·
I’m going for a retune with the BW. I want to see how much it can make and how early the boost can come on. It’s 0.91AR twin stroll divided T4 8376 S300SX airworks.
If I get full boost by 3500rpm I’m keeping the turbo if not I’ll swap it with the BB Aeroflow 6262 with a 0.83AR. It’s also a divided T4.
Discussion Starter · #105 ·
Car is back just gotta modify the shifter it’s hitting the aftermarket Tailshaft.
I did some body work to have the rears sitting with 0 cambers.
2002 Lexus IS300
Good luck, if you manage to do it, post it here first! I’m think more around 4200-4300. But I’m rooting for you! Either way it will be making some steam.
2005 Lexus Is300
My build: 2004 IS300 2JZGTE 90k on body 0km on engine.
Here is the list of mods so far carried out, the tune is not yet done (aiming for 700hp).
Engine mods:
Fully rebuilt motor.
Turbo: Aeroflow 6262.
Haltech 2000 + Doomslang harness.
Stage 2 264 BC cams.
GTE pistons and Rods.
ACL bearings and Rings
Hitachi R35 Coilpack kit.
Bored & machined bottom end.
Machined head comp 9:1:1.
Haltech Wideband Single Channel.
1.1mm head gasket.
ARP head Studs.
Spring Valves & Retainers.
Adjustable Cam Gear.
50mm Turbosmart proGate Wastegate.
XS Steampipe Exhaust Manifold.
FFIM.
Cam & Crank Sensors.
3” Exhaust system.
CX racing intercooler kit.
Greddy OLED Boost Controller.
TurboSmart Boost Gauge.
HKS SSQV Bov.
2x Mishimoto oil Catch Cans.
Greddy Turbo Timer.
Koyo Aluminum Radiator.
Oil Cooler system.
Mishimoto Oil Sandwich with thermo.
HardRace E mounts.
LX470 Oil Pressure Sender.
Proflow 90mm Throttle body.
New Starter Motor.
Power Steering Aluminum bottle.
Blitz Air filter with Custom Cover.
VW Hornes.
Clear Cam Cover.
Platinum NGK plugs.
New Timing belt.
Battery relocation kit.
Transmission:
Auto Trans control by JEMs.
3500rpm Converter.
2JZ SFI Approved Billet Steel Flexplate.
Trans single Cooler.
TT Aristo Tailshaft modified to handle 600hp.
TT Aristo 4SPD A340e Shift Kitted & Upgraded to hold 700hp:
• ATF Custom Heavy Duty.
• 2nd Gear Sprag Assembly.
• ATF Billet Accumulator Pistons.
• ATF Billet Forward 7075 Aluminum Piston.
• Direct Drum Bushing.
• Babbit Pump Bushing.
• Overdrive Clutch Pack.
• Overrun Clutch Pack.
• Forward Clutch Pack.
• Direct Clutch Pack - 3rd and Reverse Gears.
• Intermediate Clutch Pack 2nd Gear.
• Low and Reverse Clutch Pack.
• Filter.
Fuel system:
1200cc injectors.
Ai Surge tank with 2x 460 Walbro.
In Tank 460 Walbro.
Radium Auto Fuel rail.
FuelLab EFI Fuel pressure regulator.
Fuel return lines.
Suspension:
Tein SS Coilovers.
Y85 diff 4.1 ratio out of a 86.
Enkei PF05 18x 8.5 45+
18x 9.5 25+.
LS400 front brake Calipers, Stoptech Braided Lines, Dixcel Rotors and Dixcel Pads Z Type.
Rear Intima Ceramic Pads.
Rear Dimpled & Slotted rotors.
Ultra Race 19mm Rear Swaybar.
Top mount Suspension Strut brace.
Boot Strut brace.
Rear adjustable Camber Arms.
Rear adjustable Toe arms.
Enkei lightweight nuts.
15mm front spacers.
Cosmetic:
Respray Pearl White.
Full TRD neo V1 kit.
Altezza Yellow RS200 Z type Cluster.
2017 ISF Leather front Seats.
Aluminum Radiator Cover panel.
Altezza Bonnet Grill.
Sped-D Xenon headlights.
Interior Carbon Dipped trims.
Smoked LED Tail lights.
Smoked LED laser blinkers.
Rain shields.
Rear Windowscreen Shield cover.
Rolled & Pulled Guards.
Aero Wipers.
Bonnet Gas Struts.
TRD mini Antenna.
TRD Oil Cap.
CF Number plate Brackets.
Full LED interior and exterior bulbs.
Special thanks to Jacob at Macarthur Motorsport & Mechanical help me a lot along the way!. And JEMs Adam for all the Tune and the transmission control work, we’ll done boys.
I want to do my build with the auburn sky pearl color. Seeing it was my first is300 color and I don't see many of those builds around on the internet. That being SAID i'm really tempted to change my mind everytime I see one of these in white especially with the right body kit on it. White looks gorgeous on this car and I never thought I'd say that about a white car.
2001 AR5 Swap, Built NA-T, Standalone
What oil pump do you have? I imagine there's a difference in the 3sge oil pressure vs 2jz oil pressure, unless it doesn't change at all.
Real quick because we're talking about dashes, has anyone taken theirs apart to see if you can remove the red from the redline on the tach? I know you can take that panel off and replace it with a jdm or custom one I just don't know if I want to spend hundreds for that right now. I'm willing to take my own apart if there's any interest but I don't want to thread jack.
Just looked on eBay and there's a few cheap jdm ones that go to 7900, I'm going to buy one and make a thread swapping it out. Im on standalone so I can make the tach accurate.
Discussion Starter · #119 ·
I shall be getting the car resprayed sooner than I thought, painter said to call him on Wednesday he will give me a date to drop it off. Doing closed door so shouldn’t take long.
