The car made 400kw on 98 few things need to be fixed then will try on E85.
Sent from my iPhone using Tapatalk
Yeah I’m not sure. It’s quite low tbh and something doesn’t add up. Mech shop and machinist shop are for sure playing with me.I'm confused.
A hypothetical but representative 2JZ with flat top pistons, 86mm x 86mm Bore/stroke, 60cc combustion chamber, 87mm gasket bore and 1.3mm thick gasket produces 8.4:1
To arrive at 6.8:1 with that same configuration, you'd need 19cc dished pistons (or an extra 19cc of clearance volume somewhere).
Assuming you did have 19cc extra clearance volume:
Installing a 1.1mm gasket increases CR to 6.9:1
To get from 6.9 to 9.1 by only machining the head - you'd have to machine enough to decrease combustion chamber volume by 24cc, which is not happening. (and you wouldn't want to, even if you could)
Something here does not add up.
Engine Compression Ratio (CR) Calculator
This calculator is designed to show the different Compression Ratios for different sized engines.www.csgnetwork.com
Yeah I definitely love the BW bro I even had a slight argument with my tuner who refuses to tune the car unless I put the AF on it.Man I think in your case, the compression ratio would affect the spool time, more than the turbine A/R. I don’t think .91 is terrible , compared to a compression ratio of 6 - which if it really is 6, is terrible. I would run the BW on the engine with the higher compression ratio, just to see.
I’m sure the Aeroflow is a good turbo, and it ought to spool a bit faster being BB vs JB, however you won’t convince me it’s a better turbo than the BW. The Borgs are used OEM and have a proven track record.
I don’t remember what rods you are using. But if this thing is going to be hitting high boost /lotsa torque at low rpm’s, you will bend the rods unless they can handle it. Stock GTE rods can’t handle these hard-hitting, insanely low-rpm fast spooling modern turbos. So the tuner may have to keep it under control till you’re further up in the rpm range.
