Nvm
If you go better Box and bigger converter you will need a stronger flex or OEM will snap.Love the build, but i am struggling with the need for a billet flexiplate, maybe you can explain what s so special about it?
I see the ring gear outer is welded on so not part of the billet, is it just to have the hub and plate made of one piece for extra strength? Do the OEM ones let go?![]()
Haltech elite 2000 with Doomslang harness. Since I’m going with the Aristo TT A340e I’m also installing MV A340e Shifter. The A340e is Not installed yet but should be done next week. For now I’m using a Shimmed A650 without auto control thus I’m using it manually. I had to get it wired for the time being but after the new box goes in, for now MV shifter will do.2 Questions. What ECU or TCU are you shifting with? Do you have e-shift still and how did you get to work?
I believe he is a BALLER and has so much money that he should give me some lol. I think he is using a Haltech.
