1 - 20 of 50 Posts
Has anyone changed their own cabin air filter, if so, does the hinged door that protects the filter have a closure latch or is it simply gravity that holds it down once rotated into place?
IMPORTANT: Please ensure that the vehicle is in recirculate mode. If not, you will force open the computer controled damper and damage the HVAC system.
We just replaced one for a customer at the tune of $2000.00 damage from not having the recirculate mode on.
It is extremely important to follow this process on all newer 2nd gen models inclusing the IS350. As I do not own one of these vehicles, nor do I know the differences between IS250 or IS350 HVAC systems.
Here is some steps to help you.
This is from an ES350, so your HVAC control panel may look different.
Recirculate turned on, then shut the car off - I think two taps or one on the start button or key off.
Empty your glove box to reveal access door - The IS250/350 should be an "L" shaped access door - apply slight finger pressure sliding to the left and then slide up
See Picture on the left
Once the first "L" shaped door is removed it will reveal the second door
Slide up, using slight finger pressure - prongs are on the bottom, once up it should just pull out and away
Stop! If you now see a third door blocking the way - you do not have the HVAC system in recirculate mode - If this door is forced - this is where the damage will happen
Proceed! If you have a clear veiw of the filter and basket
Should now reveal the filter cover or end cap or filter basket- This now needs removal.
See exact example below for the IS250/350 - Picture on the left side
You should now be able to remove your Cabin Filter by pulling out of the basket
Note the position of the filter, when removing to ensure you put the new one back in the same way. The filter will also be marked with an arrow point "UP" and physicaly state "UP". The ES350 did not have a basket, yours probably does.
See pictured below on the left side for IS250/ 350
Re-assemble in reverse order
Digger08
Reactions: kayotik
Ninja?
Digger, absolutely correct. And yes, it is the same procedure for both vehicles. 250 and 350.
I had to edit, as I think I missed a step. Now fixed as I missed the "L" shapped door
Digger08
Thanks for the very important information!!. BTW, you mentioned $2000.00 repair, what exactly happened that amounted to that kind of money?. Also, for my own knowledge does the recirculate mode open the door allowing access to the filter?
Thanks Again
Ninja?
Thanks Again
The bulk of the cost is probably labor charges. Opening the door without the recirculation on will break a lever or something like that. They have to take apart the entire dash to replace the mechanism. I'm pretty sure the mechanism is costly as well.
Actual figures were:
Replacement HVAC part was $2,840.00 CAN
Labor = 7 hours at 125.00 hr. =$875.00 CAN
Plus taxes at 15%
= was in the $4200.00 range.
When the door is forced, it breaks the damper attachment point and requires an entirely new HVAC system.
Note: this was not a personal damage fault , but the mistake of aftermarket service technician. So my company had to pony up and repair this through a dealer to make things right. Big mistake for such a small part.
In defense, Lexus did not issue any warnings on this untill June 2008
Digger08
Discussion Starter #8
As far as I can understand the broken bracket would make the re-circulating setting inoperable. Most people avoid using the recirculating setting as it causes fogging of the windows. Why would someone be inclined to spend such an exorbitant amount of money for something so unimportant?
Just wondering... because the amount seems almost ridiculous!
Apparently you need to read my last post again as to why it was repaired and no, the broken bracket, effects the entire system not just the recirculate mode.
I would think that if it was your car and someone else broke it, you would expect nothing less than the proper repair.
Digger08
Discussion Starter #10
I totally agree with you on every account. My statement was a result of my surprise of the cost. It just seems unlike "Toyota" to design something in this way.
My apologies.
What are the signs that you have a broken cabin air filter recirculate lever? Is it something that can only be determined during another change of the air filter?
Ninja?
uh... press the recirculate button and see if it works or not?
If this was broken during servicing would it stop working directly after it was broken? The recirculate mode seems to work fine, it is the fresh air button that seems to be having issues. I am wondering if these two are related?
Ninja?
yes. it is directly related.
Ninja?
Is it possible to break this piece during servicing and have it work for a few months before it quits working?
No. Once it is broken it should not be working for a few months. it's a fairly fragile piece.
So, if I had my car serviced 5 months (and the filter was changed at that time) ago and it just stopped working two weeks ago, how else would that piece break? If this is a fragile piece, could it break on it's own?
Ninja?
If it was working fine after the service, it may be something else. I suggest you take it to the dealership if you are under warranty.
Was it serviced at the dealership?
It was working fine for five months (I used the heat or air conditioning on the recirculate mode every day for that time) and then one morning I hit the temperature up arrow and it started making a loud clicking noise. Now it makes that loud clicking noise every time I use the fresh air feature.
I had Lexus look at it and they told me this was the piece that was broken. Is this something that should be covered by a warranty? I'm still well under my warranty.
Sorry, correction - I used the heat or air on the fresh air mode!
Ninja?
You didn't specify if you got the service done at the dealership or not. if the dealership serviced it, and they are the cause of the damage, the warranty should cover it.
If you had the car serviced elsewhere, you or that shop will have to pay for the repairs.
(~$2400)
1 - 20 of 50 Posts
