1 - 14 of 14 Posts
I was browsing the web today, and came upon this site
http://www.sydneycitylexus.com.au/Showroom/is200.asp?department=New Vehicles&pagename=IS200
it's the IS200 in Australia. If you scroll down, it says it comes with a 6cyl DOHC motor, and with the option of a 6spd Manual or 4spd Auto....
is this correct? i always thought IS200 was 4cyl for some reason... and i never knew you could get a 6spd from lexus for the IS
Engine
Engine Type Petrol
Engine Capacity (cc) 1988
Engine Code/Name 1G-FE
Engine Description 6cyl/DOHC/4v
Maximum Power 114kW @ 6200rpm
Maximum Torque 195Nm @ 4600rpm
Highway Cycle (L/100km) 10.5 / 10.0
Drivetrain
Driven Wheels Rear
Transmission description Six speed manual / four
speed automatic, electronically controlled with lock-up torque converter.
Brakes
Front Brakes Ventilated discs
Rear Brakes Solid Discs
Traction Control STD
Anti-Skid Brakes (ABS) STD
B2001AS said:
I don't think it's a I-6. It's a V6 i think. They never have I-6 on 6 spd manual. please correct me when I am wrong.
Here are Lexus IS200SE specs from UK:
2.0 litre engine
VVT-i - Variable Valve Timing - intelligent (electronically controlled)
ETCS-i - Electronic Throttle Control System - intelligent: advanced computerised engine management system
6-speed manual transmission or 4-speed Electronically Controlled Transmission (ECT-i) with intelligent computer control
AI shift system
Dual stainless steel exhaust system with catalytic converters
Cylinders/valves: in line 6/24
Capacity: 1988 cc
Compression ratio: 10.0:1
Stroke/Bore: 75.0 x 75.0 mm
Maximum output: 153 bhp (114 kW) @ 6200 rpm
Maximum torque: 144 lb/ft (195 Nm) @ 4600 rpm
RS200AT said:
The 6sp is the J160.
The Toyota Altezza RS200 comes with the 5AT or 6sp manual and 4 cyl.
The Toyota Altezza AS200 (aka.Lexus IS200) comes with 4AT or 6 sp manual and 6 cyl.
RS200AT is dead on. This is your answer.
Sleepy, vlad_a, and llt are right, there is a a 6 speed on the 2.0L I6 Toyota makes, as well, the Supra also had a 6 speed (3.0L I6 TT).
And here's a dot for ya! 8)
1 - 14 of 14 Posts
