1 - 18 of 18 Posts
in the lexus an interference motor. For example, if the timing belt slips does the valves hit the pistons?
Katie
Katie
i would suggest posting this in the go fast area for a FAST REPLY.
PS 05 is having a new body style and motor, you might want to see what it looks like before you get an 04.
is300soon said:
Katie
I'll check it out thanks.
I think I figured it out after roaming the search for awhile. I got that the motor is not an interference motor-good. I just came from the dsm side (I owned a galant vr4) and have had experience with a tensioner failing.
Katie
Mr. Negative
yes the 2jzge engine in the IS300 is a valvebender... :cry:
Katie
Welcome Katie,
trust me! it's an intereference motor! long, expensive story.....haha
Kane
Katie
According to the Gates belts website it is NOT and interfence motor. No Lexus motors are apparently.
http://www.gates.com/brochure.cfm?brochure=981&location_id=540
Click on the link for the "timing belt replacement guide PDF" near the bottom of the page.
From what I can tell, no Toyota car engines have an interference design. Some of the trucks, i.e. Diesels and the 4.7L V8 in the Tundra do though.
is300sam2002 said:
If you don't believe it, remove cam belt, crank engine, find out.
Try it yourself and report back :lol:
Any motor, interference or not can bend a valve if over-reved. Also, shaving the head, or fitting non-stock pistons can turn a non-interference design into one that now will have intereference.
I didn't say to over rev it. This has all ben gone over before. The Gates thing is a mistake. Ask the guy that tried it while installing his cam gear.
Mr. Negative
believe what you want. It is interference. Like someone said, remove the timing belt and have fun. Kanine knows better than anyone.
wjbertrand said:
Katie
Discussion Starter · #14 ·
Okay thanks guys-the search provided false information. Thanks for the welcomes although I have been on this site since 2001 but forgot my password. I want to purchase an is300 and turbo it-eventually...
Katie
yes, it is interferance. toyota engines with VVT-i are all valve benders. The old 4.0 v-8's (befor 98 when vvti was introduced) were non-interferance. I wouldnt trust your "gate's belts" website for anything. check the factory serv. manual. it also states interferance engine!
For references sake, the 2JZGTE (Supra, Soarer, Aristo) is NOT an interference engine. They switched over to VVT on the 98 GTE's and I'm almost positive that is not an interference engine either.
Ryan <--- New guy from the Supra community
Anyone ask Lexus/Toyota directly?? Got a copy of the service manual that states this is an interference motor? Not looking to prove anything, I just want to know for sure one way or the other.
Mr. Negative
it's interference. damn......
Ryan is saying the GTE's weren't. that's because they have a different head, piston, and a thicker gasket.
The only real question in my mind is, "Is the stock GE motor in the IS a valve bender after adding a headgasket spacer like what comes w/ all the turbo kits?"
1 - 18 of 18 Posts
