1 - 11 of 11 Posts
BigDaddyRich said:
Does anyone make a SET OF TWO that works with VVT-i?
Not yet. The vvt-i cam gear is a whole special unit that has hydrualics and a couple wierd mechanisms in it. Not exactely easy to produce.
It states in the FSM, that if you remove the Cam gear from the vvt-i mechanism, to replace it with a new one. :eek: They don't even say it's fixable. I guess it has some sort of calibration to it.
Kane
you don't need both
you already have an adjustable cam gear on the intake side, as factory equiptment, it just isn't adjustable by you. its far superior to your mechanical adjustable cam gear, as your cam gear will probably adjust + or - 10 to 15 degrees, the factory IS gear is + or - 30 degrees.
i would think you would be more interested in figuring a way to adjust the vvti cam gear, electronically, from the cockpit
-gte
So is this junk "Adjustable Cam Sprocket JDM
OBX Lexus IS300 00-Up Adjustable Cam Sprocket - Silver. Brand new and still in its factory sealed box. OBX Precision Adjustable Cam Sprockets are available for a wide range of popular sport compact car applications. Engineered 5-point locking bolt design prevents accidental slippage during high RPM. Extremely lightweight aircraft grade aluminum is used to withstand extreme revolution during competition. Hard baked anodized gear teeth extend the longevity of the product. Dyno tested for 5-20 horsepower gain as well as durability and structural strength.
Features:
Advanced 5 point locking design with stainless steel bolt
Lightweight T6061 T6 aluminum aircraft grade with precision and CNC computer machined
Adjustable +/- 10 degrees (advance/retard)
Laser cut setting for easy adjustment
+5-20 Horsepower gain
ebay Item #2440099153
Guys dont flame me I'm just trying to contribute and ask a valid question :D
Wino_II said:
I know of two cars with adjustables on both sides. 8)
I know of about 5 in total that are that way....But none of them still have VVT-i and that was understoond in the question....If you just wanted to say it to be cool my apologies.... 8)
Dan
02' MSM IS300
.....TOYOMOTO Built.....
...BULLISH RACING Enhanced...
..."TOYOMOTO & BULLISH RACING.....When you care enough to ONLY use the VERY BEST"....
IS300GTE said:
you don't need both
I know that much mang.... I was thinkin of if some tuner may have prettied up an OEM Toyota intake cam gear to match their Exhaust Cam So it doesnt look as odd if you add "just" an HKS exhaust cam gear for example.
Kinda like if HKS would anodize an OEM VVT-i cam gear blue and purple?
Wino_II said:
Yes, it was said to be cool. :roll:
Missed this reply.....The thread was started about having two cam gears and still having VVT-i....Now why would you post about the two you know of ??? Unless of course they have VVT-i(whcih they don't).....So the choices are either (a)You were bored and felt like posting.....(b) You wanted to get some attention to SRT and feel cool... or c) You know of two guys that have VVT-i and also have two different cam gears.......I'll venture out on a limb and go with B....
Lastly no need to eyeroll there cool guy.... :lol: :roll:
Rich to answer you....Nope nothing exists yet.....I don't think it'll happen for a while.......
Dan
02' MSM IS300
1 - 11 of 11 Posts
