Penetration Specialist
hey guys. I'm pretty sure how to install the rotors and pads from sOy's post (thanks)...but I had some questions about installing my ss brakes lines and bleeding the system. does anyone have any tutorials or pics that would be helpful.. thanks!
I'm thinking of one "must have" and one "helpful" item...bleeder & brake line wrench.
The hardest thing is to get the caliper bolts loose. Better go hose those suckas down with some Liquid Wrench...now.
You'll need someone to help you or if you're going solo, you'll need a vacuum bleeder. Work on the brake furthest from the master cyl. Once complete bleed the brakes then move to the next brake that second furthest from the master cyl, etc. Make sure you keep an eye on the brake fluid level and refill accordingly otherwise you may suck air into the brake system. Good luck.
If you need more information than this, then I would suggest you get a manual.
LINE WRENCH!!
Stop by and u can borrow mine. Little bastards expensive.
Pick up some loc-tite for the caliper bolts.
Torque wrench, brake fluid.
Its truly unbelieveable how tight these parts are to break free for the first time. So be careful. I had to crank hard to get the factory line to stop leaking after installing my SS lines.
Give me a shout tomorrow.
After looking at your sig; it would appear to moi that one of us has waaaayyyyy too much disposable income :lol:
Good luck on the install.. :p
Wino, i never got motivated to do my pictoral How To Change Your Brakes Guide, but I have allt he photos at home if you want 'em... PM me and I'll do my best to get them online for you asap.
