but most importantly! must use the almightly search function!
theres tons of info jus have to click!
but lets put it this way... if you're not sure i'd have them done professionally! don't wanna mess with the brakes if you're not sure...those things save your life, i wouldn't chance it if you aint sure... jus to save a few extra bucks? okay maybe a lil more :lol: but you get the point.
but if you really want to do em yourself, then its pretty much straight foward...take wheels off, clean the wheel hub while you're at it, bleed the lines, take caliper off... outer & inner, reshim, then go in reverse... more or less. after that you jus have to brake in the pads so to speak.
don't ask me how exactly to do the IS, i've only changed brakes on a corolla, thou all cars have the same parts
with that said...
brakes aren't a DIY unless you really know what you're doing.
in the end its all up to you, so if saving a couple of bucks is worth it, then by all means give it a try
