1 - 13 of 13 Posts
Hey guys, where can I find the instructions to install these bars.
What should I do with the Front:
Rear:
Trunk:
Sorry I ran searches but they didnt pertain to installation and most of them were arguing which bar was better.
Thanks :p
Here is the guide for the front strut bar. It is for the JIC, but no difference for install. A hint I could give you is that the front bar will bend a little when you are trying to put it over the studs. Just put one side on the studs and take the other with two hands and gently bend it and get it to fit over the studs on your side.
http://www.is300.net/modules.php?name=Content&pa=showpage&pid=11&cid=7
Trunk bar shouldn't be that hard. I think you just lift up the carpet (Ya might have to twist some of the tabs off), and take off 2 bolts , put the bar down, and put the bolts back in.
THANKKKK YOUU
I wuv zyuuuuuu :crazy: :crazy: :crazy: :crazy:
I am installing the fronts right now, my bars are in, now are there any recommendations to putting the daytime harnesses and such back on? Does placement matter?
Thanks. I should have looked more carefully :lol:
Now with the rear braces, I have to remove the carpet. There are screws that i can take out easily, but there are these pegs that do not come out. How do I take those out. By pulling too hard, I broke one of them and carpet got ripped. :pissed:
Also, where does the Trunk brace go?? When I bought it Gordon @ Carson said he didn't know :x
Thanks
Nygmatic
tis best to lift up the car by the center support prior to tightening the strut bar as this will unload the corners. when you put the bar on with unloaded corners you will get the most rigidity after the install.
Any tips in removing the plastic trunk tabs to take off the carpet cover??
I'm relaly in need of help.
I just took a flat head screw driver and inserted it in the slit and pryed them off. The screw driver that comes this the car works well for this.
Threadlocker
go buy a panel popper at an autoparts store.. using a screwdriver you may break the plugs, which cost like 15 bucks each at the dealer.
1 - 13 of 13 Posts
