pwrhockey said:
vlad_a said:
There is a possibility you are mounting it in the wrong spot. :shame:
Gee Mr. thanks for your quality post but mabey you have never seen this shield........You would have to be a complete moron to try to mount it in the wrong spot, not to mention that you are a moron if you don't know where you exhaust manifold is.
Moving on.....I was there helping with the install and it just didn't want to go in there, we just thought we should check to see if other people have this problem AND they did. We just wanted to see if anyone had a solution.
There is no reason to be rude, noob! :shame:
Let me guide you through:
1) You have INJEN intake.
2) You have a heat shield.
3) #1+#2=You have Injen intake with a heat shield that came with it.
Obvious, right?
Here is what may not have been so obvious to you:
YOU ARE TRYING TO MOUNT THE HEATSHIELD IN THE WRONG SPOT! :shame:
Therefore, my post may have been the most helpful.
The heat shield does not go over the exhaust manifold. It makes no difference if you do or do not know where it is located. :lol:
Read the manual, look at how others have installed it, you'll figure it out. :chill:
