You will need at least a 32 offset to fit it. Pictured below is a 42 offset 9" with a 10mm spacer.
Just in case you were thinking about it.
HOWEVER as i an getting stupider every day. I forgot to put the brace rotor on. DUHHHHH. So puting that in i am able to use ONE 5mm spacer and have 4mm of clearance now. So that gives it a 37mm offset.
So as stated belew a 38mm would work fine.
