revv stays at 3 all the time when it`s in neutral gear, cleaned the throttle body but didn`t help.
can someone help me please does anyone know how to clean position sensor?
what else could cause this?
recently changed fuel pump of different car could this cause the problem?
thank you
I have you done anything to the car recently such as mods or maintenance work??
well i would defintly start at the throttle body and inspect the throttle position sensor, accelerator pedal position sensor :) Not sure if you loosened anything when cleaning the throttle.
I already had this problem and afterwords cleaned throttle body, if it`s accelerator pedal position sensor can it be cleaned? throttle body has two sensors right? I took one apart but it seems ok, the another one is too difficult to remove can`t even get to the screw to undo it, I don`t even know how to check they work or not ((
Cherisher
Pull your codes and post them.
Do you have an IS200 or IS300?
