1 - 9 of 9 Posts
I totally hate the traction control. The fact that it still kicks in even after I shut if off. I was hoping if anyone can help me on this so I can get back to learning drifting ASAP!! Thanks very much.... I have no problem drifting in the RX8.... love that car too.
once u click that little button its off until u shut the car down and turn it back on, then its back on.... Its a normally open switch i believe. You can bypass that, but the TRAC light becomes VERY VERY bright in the dash. He is prolly talking about VSC in his car. That you have troubles with.
David
David
normally closed (circuit) switch, meaning normally on. 8)
well atleast u kno what i mean :)
David
The track switch is normally off, as in shorts the wires when pressed.
One of the members used a timer relay to turn trac off whenever the car is started.
1 - 9 of 9 Posts
