1 - 20 of 21 Posts
Let it dry. :roll:
Keep the windows open, provided there is no rain.
Remove some of the moisture with towels.
DO NOT use hairdryer. :lol:
newlex said:
do you think thta i need to take the seat apart?
I don't think that you do.
did the same thing with my prelude, but left the sunroof open. seats were soaked. not much you can do. drive with towels in the seat. better that water soaks your seats and not the floorboards.
Try a wet/dry vac to remove most of the water. It will make it dry alot quicker if it's not completely soaked.
:lol: I did the same thing in my Gen-V Prelude!
My girlfriend's IS got about 2 inches of water in it durring a flood and I had to rip out the entire interior and dry it. If water did get in the carpet you cannot get it out with a wet/dry vac :shame: the padding under it holds moisture and will mildew and smell like shit. It takes about 5 min to take out the seat, trimming, and carpet I suggest you do so and replace the padding.
After you remove as much water as possible, I would highly recommend leaving the doors open (if you can) and run a fan on high so it forces air through the car and moisture out. Place it on the driver's seat and aim it at the passenger seat. It will speed up the drying of everything....
My ex left the window to her Integra open...I took out the seat, wet vacced the hell out of it, then ran a fan on high all day long. Moving it every now and then to dry everything....it worked great.
If the foam under the carpets got soaked, I'd suggest removing and replacing the carpet. The reason being, that foam can be a harvest ground for mildew - therfore you will get that nasty humid-like smell if it remains wet...plus stuff will start to rust.
Best of luck...
1 - 20 of 21 Posts
