Alright guys most of you know
I ordered a motor from JDM montreal Please see review in NORTH EAST section
http://my.is/forums/f110/buyer-bewa...on-p1mmiz321-live-com-2jzgte-purchase-507562/
I just decided to do a COLD compression test.
Here are the numbers
Cyl 1 70psi
Cyl 2 30psi
Cyl 3 35psi
cly 4 40psi
Cyl 5 45psi
Cly6 30 psi
I filled motor up with oil hooked up a starter and cranked it.
I pulled the lower oil pan off and a milky goo came off, from the oil I JUST put in 10 minutes earlier.
Here is a picture of some of the remains coming off the block
There is clearly water in cylinder 4 and some goo
My oil pan is also dented in!!!
And someone RTV'ed this whole engine together. Not a single stock gasket is in place anymore...
My suspect this head is warped... Anyone else have any insight?
Cyl 1 70psi
Cyl 2 30psi
Cyl 3 35psi
cly 4 40psi
Cyl 5 45psi
Cly6 30 psi
