1 - 12 of 12 Posts
How well do sway bar's work, how do you like them, and do they make the car handle much better? What about helping understeer? Thanks
check out the "stop, drop and roll" section.
you'll have tons of infos
[ October 18, 2001: Message edited by: mystic ]
I think I inadvertantly did a good test - I had my springs/shocks changed, and they forgot to tighten my rear sway bar - it was loose and therefore not working at all. I did a 2 day track event with basically no rear sway bar. I did notice the car seemed to be understeering a bit more than usual, but figured it was the springs. In fact, I didn't figure anything was wrong til the bar started rattling bad on bumps, then had the car checked and they found the 6 bolts all loose. Once the bar was reattached, I did notice the car understeering less on very fast cornering, but I still think the effect of sway bars is exaggerated, especially compared to stiffer spring/shocks, which are MUCH more noticeable. And they will NOT really improve handling quickness, they just reduce understeer (if the rear is increased - adding a larger front sway does nothing).
Ckolsen: I don't think the effect of sways is exaggerated at all. Case in point was my old Integra Type R... That thing had a monster rear sway for a 2600lb. car (22mm!). It changed the balance of the integra from an understeering fool to a slightly-tail-happy FWD car.
They really do have a noticeable effect on handling balance.
Ducati, how do you know the sway helped the handling? Did you ever take it off? Because the Type R has a lot of changes over the GSR, so unless you took the sway off, I don't think you can say what its effect was.
On 2001-10-19 07:29, ducati wrote:
Ckolsen: I don't think the effect of sways is exaggerated at all. Case in point was my old Integra Type R... That thing had a monster rear sway for a 2600lb. car (22mm!). It changed the balance of the integra from an understeering fool to a slightly-tail-happy FWD car. <P>They really do have a noticeable effect on handling balance.
Sway bars make a huge difference.. I have H&R's on my IS...
I went in a test drive in someone who has an IS as well with just TRD Race Sway Bars.. It was a HUGE difference.. Cornering was improved by a lot! no more leaning whatsoever.. no more rocking right and left on turns.. felt much tighter... I would highly recommend them.. I'm actually getting a set very soon.. If any one wants a great price let me know..
I think sway bars should be viewed as tuning devices to either tweak any undesireable handling characteristics or create a different handling manner.
The degree to which sway bars affects the ride of a car is completely dependent on the car they are on and the suspension setup of the car either in OEM trim or aftermarket. IMO it all comes down to a matter of degree.
Would the TRD race sway bars make a noticeable difference on the OEM springs and dampers. The answer would have to be YES. I'll go out on a limb and say a large difference.
Would the TRD race sway bars make a noticeable difference on an IS 300 w/aftermarket springs and shocks. Probably yes, but to a lesser degree.
I did incremental suspension mods. I first installed the TRD race sway bars and drove around w/the OEM springs/dampers for 2-3 months. The ride change was dramatically improved. However, once I changed to aftermarket springs and shocks, the change was not as noticeable. I never had the chance to drive the aftermarket springs/dampers w/OEM sway bars so cannot make a statement on that set up.
Ultimately, I don't think a blanket statement that sway bars don't do that much is necessarily accurate. IMO they always make a difference, it's just a matter of degree.
<TABLE BORDER=0 CELLPADDING=0 CELLSPACING=0 ALIGN=CENTER WIDTH=85%><TR><TD COLSPAN=2><font size=-1>Quote:</font><HR></TD></TR><TR><TD> </TD><TD><FONT SIZE=-1>
</FONT></TD></TR><TR><TD COLSPAN=2><HR></TD></TR></TABLE>
Couldn't agree with you more, Risk. Sway bars, in actuality, make an independent suspension less "independent," so why overdo it? A stock IS is already very competent in the handling department. But like most cars, it looks (and handles even) better when it's lowered.
On a race car, yeah, go all out--make everything proportionately stiffer. But go overboard on a street-driven car and I think you'll find that over typical irregular road surfaces your overall ride quality will suffer *and* your overall grip will actually go down because the tires can't maintain as much contact. Not something you want during a street road race...
I would have to agree with Risk:
He is the one that I first spoke with about the TRD RACE sways, after he ordered/installed them and I have to say that everything that he has stated above is nothing but the truth. I have the TRD Race sways installed and the diffrence between OEM and the TRD Race Sways is night and day. IMO ofcourse. I run autox events with my IS and I enjoy driving my car. The sway bars have improved my autox times and made driving on the road a more accelerated experiance when turning. As for ride quality, I have personally not experianced any loss of ride quality. I have noticed that yes when extreme turning is encountered that the car will break loose, but I believe thats my fault folks, since my sway bars I can push the car that much harder when turning so breaking loose the tires happens. hehehehehe As far as street racing, unless you are trying to comit suicide, last I checked racing in traffic is a morons game IMO. If I had money for everytime some punk in his 3 series bmw tried to run me on the highway and almost kill us both I would be a very rich man.
Just my 2 cents
<IMG SRC="/forum/images/smiles/icon_cool.gif">
_________________
Anthony
GGP,01 IS300
I have work done.
God bless America and all the protect her.
<font size=-1>[ This Message was edited by: AECIS300 on 2001-11-21 16:17 ]</font>
1 - 12 of 12 Posts
