I’m not sure if my memory seats are working. How do you actually use them? First I pressed the first button and set together for 5 seconds. Then I moved the seat in a different position. Finally when I pressed 1 and held it down, it doesn’t work. Am I doing it correctly?
I don't have memory seats on my 02' base model but my 06' 4runner Limited has them. I know on mine I need to press and hold the "SET", THEN!!! "1 or 2" for a couple seconds to it beeps and then release. I wouldn't press the buttons at the same time. It should be similar on all models of Lexus and Toyota.
There's a lot of answers on the internet you can search directly for it. Or else, find someone who can help you with it, who can explain clearly to you how to use it.
