Does it annoy you that you can't turn your fog lights on by them selves? The IS requires you to have the headlamps on before you can switch on the fogs. This quick mod will bypass that check, and allow for the fogs to be on by themselves.
ratchet with 10mm fitting, wire strippers, crimping tool, fuze puller or tweezers plus 12" of 16 gauge wire, 1 female wire spade
2/5
About 15 minutes
113
114
115
116
117
118
119
Thanks to TEG who originally thought up this idea, and to UCLA-IS300 for his revisions.
For a optimal connection at the fuse, use the BUSS mini-add-a-circuit device. You will need to pick up another 7.5A ATM fuse and you won't need wire. See the posts in the thread, but it will look like below.
2/5
About 15 minutes
113
114
115
116
117
118
119
