1 - 13 of 13 Posts
As Im sure with all the enthusaiste IS drivers in this forum, lots of us have stickers sticked to the side window. (the small triangle spot)
I was just wondering... are there are special ways to peel them off safely without leaving sticky bits on the window?
The reason why Im worried about the after effect is because I had the stickers for at least 2 years now.
Thanks
even if theres "sticky bits" just use goo-gone and a razor blade , dont use the corner of the razor to scratch off the sticky bits, but have the blade flat, and scrape it off.
...what he said
peel then use wd40.
D
Single edge razor blade, with a soap and water solution.
The soap re-activates the adhesive, and makes it really easy to come off when using the razor blade.
RE-Activates!!! HA HA HA AH AH. Good one.
No it doesent. The water stops the glue from re sticking thats all. Thats why they use soapy water to put stickers on in the first place. So it doesent stick right away and lets you push the bubbles out.
Discussion Starter #10
got it.. thank you guys!. Doing it tonight
1 - 13 of 13 Posts
