How much do your Moda's weigh?isthrizzy said:Well, if you go with the recommended size for +2 sizing, your overall change in diamter will be almost negligible. The problem with acceleration comes from the added rotating mass of the 19s.
Thanks for the link. Very helpfull.danielm said:Use this http://www.miata.net/garage/tirecalc.html make sure your 19" wheel diamiter with new tires are the same as stock and you wont "lose" anything.
Stock 215/45/17
You need
235/30/19 or 225/30/19 will work too.
Play around on the link you'll be ok.
