1 - 2 of 2 Posts
Hi, everyone. I searched around the forum, but I all I can found are removal for front door. My rear power door lock stop working, I bought a new actuator but can't remove the panel. Please help. Thank you.
The inner door handle has a cover, pop that off and there should be a phillips screw. then remove the power window switch and it should reveal another screw. The rest of the panel is held up by plastic clips.
1 - 2 of 2 Posts
