1 - 19 of 19 Posts
i want to remove the residue left from the visors and its drivng me crazy...any suggestions?
thanks in advance
by visors do you mean wind deflectors? spray some WD40 ont here (DONT GET IT ON YOUR WINDOW), and just start working it with a fingernail.
yes the ones on your windows....wd40...sounds good. thanks man
don't they sell window residue removers in japan? that was one of the first things i bought for my car there. spread it on and scrape off with a razor blade or the plastic blade it comes with.
blow dry it a lil, melt it, then wd40
sam_riceburner said:
"goo gone" at autozone
Googone will actually eat you paint. WD-40 is your best bet.
If it ate your paint, you were doing something ridiculously wrong. :suspiciou
Goo Gone is my buddy, and it's safe on paint.
I use this stuff called "Lift-Off" adhesive remover. It's in an aersol can, and can be found at Home Depot.
It's safe on paint, and won't stink like goo-gone.
I wouldn't go the WD40 route unless you had no other choice.
you could be ghetto and use some of your jdm gasoline on a rag
yea whatever u say never hurt mine
its actually true. it will eat the clear coat. you can eliminate this by using tape over the painted areas, or just be careful
thanks in advance
i've used bestine thinner... does the job and evapoartes quickly. find it art supply stores
Discussion Starter · #19 ·
the wd40 worked fantastic. thanks for the quick responses and advice
btw there are no "autozones'' here :lol:
autobacs is the closest thing
1 - 19 of 19 Posts
