1 - 20 of 39 Posts
The second Gen IS comes with the built in LED for the Cupholders
i was bored today and i figured i try to attempt the same thing.
so if i had my waterbottle in my cupholder it lights up
i did this on my 2001 Is300 E-shift
Tools:
Dremel with Drill bit
Plyers
Patience
flathead
Dremel
Step one, Clear out your Cupholder, ashtry, take break
Step Two, Pry up the gearbox ring with flathead, and handbrake boot
Step Three, Once you have the ring off, put the Car into Neutral by turning the key in acc and steping on brake.
Step Four, Pry up the Gearbox face, it takes some moving around
After that is off you'll see a clear thing like this
Step five, take your flat head and wedge between clips to lift up the clear shield, take another break
Step six,
locate back wire and bulb that goes into the shield thing. disconnect it
Step seven, remove bulb for safe keeping and Drag that wire to the handbrake
Step eight
we start Drilling! i drilled into the top right corner of the cupholder to avoid hitting any cup
i suggest you drill it a little lower than where i have mine b/c i can into complications with the cupholder lip closing.
Step nine, put everything back together and make sure it works.
FYI, This is a permanent Mod, hole in the cup holder thing. And remove light from gearbox while driving at night.
So what i did was take the light from the gear box and placed it in the cup holder
results =
im putting some leds in the future
its time for me to clean my cupholder!
Happy modding
- Dannknee!
Couldn't you have just tapped that wire that goes to the shift plate for another LED instead of losing your gear shift illumination?
That's pretty neat, I didn't know the second gen IS's had that from the factory. Great tutorial! +Rep
\/ Awesome \/
Very cool mod, I never would have thought about doing something like that. You could have just wired in an aftermarket LED though couldn't you? That way you could keep the LED in the gear shifter stock.
+rep, I might end up doing this with a separate LED since I have a manual :rolleyes:
The 2IS doesn't have that from the factory. There is a little crappy LED in the compartment area that doesn't do anything practical.
This "mod" is an option if you get a Scion though. Swizzle.
\/ Awesome \/
I for one would love to be able to see the contents of my cup holder at night. I always put my phone and wallet (and whatever else is in my pockets) in the cup holder when I drive. It's sort of a pain not being able to see it at night.
sweet! how much do you want to charge for you labor lol
Looks sweet buddy! Have some rep.
yeah my mod just gave you guys some idea, to perfect or even take it a different route. i wasnt using the light in the first place so i figured why not.
gateway mod
just makes me want to drink more water :)
thanks guys :)
Guru of Supercharged ISs
exactly....?
why not just run a led to the cup holder & tap the power off that wire powering the light for the gear illumination plate....?
just as easy really & does not disable anything OEM....
somebody broke the first rule of "Midnight Modify Society" and modded before nightfall.
I see sunlight!!!!! :lol:
great idea! +rep bro!
Discussion Starter · #20 ·
hahha i know
there are certain things we cant do at midnight :)
but if yo notice the cupholder picture with my finger is at night ;)
1 - 20 of 39 Posts
