1 - 20 of 25 Posts
I am planning to install the HID kit in my IS, but I have no idea how to take out the cover plastic and the light bulb, did anyone here had done their HID? pic would be help...thanks!!!
Stay tuned, some of the experienced .netters may supply the 411 soon.
Follow the instructions on the HID kit
Have to drill a hole in the dust cap etc...
I already installed the ballast. Next i have to drill a hole on the duct cover and connect all HID kit harness to stock harness.
Excuse my ignorance for I'm not well versed with the new IS250 & IS350 - - but does it not come with Bi-Xenon HID along with the Adaptive Front Lighting System (AFS)??? :confused: :blush:
HID is not standard on IS250 or 350. Not sure drilling the hole on the cover is a good idea or not. Any suggestions?
How else will you get the rubber cap that hides the hole you have to drill to get the light in the housing?
it is ok believe me
I have done kits in a couple of my cars, and each time drilled the hole, taken the rubber seal and popped it on
You are gonna have to drill a hole in the dust cap otherwise those wires aint gonna go through. Just make the hole as small as possible and force the wires through, Thats what i did to my brothers accord when i installed an HID kit with his projector headlight housings and it worked perfect, no dust or anything gets through :cool:
Discussion Starter #13
Thanks for ideas...do you need special tools to take out the huge plastic that cover the rest the engine?? I am afraid to break those tiny screws...Japanese start making things so complicated, even worse than Euro cars
In addition, I am planning to add a tower bar to my car, is there any adverse effect on handling?
it is ok believe me
Hey buddy, check this out. The kits that i sell now, i noticed on the box the phrase "car cpu reprogramming not required."
Now, if you were a BMW fan, you'd know that many HID kits will throw "low beam failure" on the check control system. Just found out yesterday that these new ballasts don't throw the code.
Thought i'd let you know about that. I was excited...
As for the install, most kits have the rubber grommet that keeps everything sealed up. For my installs i usually put a bead of silicone in the groove of the rubber grommet just to keep everything really sealed up.
I'm going to have to disagree there. Euro cars have parts that are practically built like disposable cameras.... One time use...
Sounds good man
I want to attempt to get the c/f tails started this winter
Have a nice garage to work in now
Yes it will
is there one for the new IS is the question
And there answer
None that I have seen yet, it is a lux. car so we shall see :lol:
Please update us when you finally install the HIDs. My car arrives this Saturday and the first thing I am gonna do Sunday morning is install the HIDs. Also could you let me know if the HIDs trigger any lights or messages on the dash.
BTW does anyone know what the low beam headlight number is on the IS350? I would like to buy the HID's sometime this week so I have them when the car arrives.
Thanks,
Joey
I drilled the hole on the cover last night. Then I found out the HID kit connector didn't fit to the stock harness. i have to cut the connector to make it fit. It will take some time.
You are right, the bi-xenons do come with the adaptive front lighting system.
But AFS is an option, so if you don't get AFS, you don't get HIDs, just regular old halogens.
Podiatrist
1. Install ballast
2. You need to get the wires from the ballast into the headlight somehow. You can drill a hole and get a grommet at home-depot or something so that the wires you put through will be nice and snug.
3. You need to connect the ballast to the factory wiring. Just connect the +12V and ground to the +12 and ground on the ballast and you should be all set.
1 - 20 of 25 Posts
