1 - 20 of 29 Posts
Penetration Specialist
Discussion Starter · #14 ·
Ok cool, that was the one I was looking at.
The order of my wires are either different, or GTE didn't color code them correctly. But in this picture:
SP2+ is red and SP2- is blue.
However, for me, the order is changed. SP2+ is blue and SP2- is red. :-?
So now that I know where it is, I need to connect that one orange wire. Does anybody know which one is goes into?...sp2+ or sp2-?
BTW, it says to tap the "ECU Speed Output Wire".
looks like the blue with yellow stripe..
Nice I see the blue with yellow stripe. My last question would be how do I actually connect the orange wire? I don't have the wire tap with me because my shop has it. They didn't know where the wire was either so they have the wire tap that came with it.
Can anybody give me a breif explanation as to how I go about connecting the orange wire to the blue w/yellow stripe? Do I need that wire tap that was included or can it be done with something eles some other way?
Thanks for all your help!
use any wire tap/splicer.. they all work the same way. OR you can strip the the blue/yellow strip wire a little then solder the orange wire on, BUT dont cut the blue/yellow strip wire!
1 - 20 of 29 Posts
