I just did the fog lamp mod a little different, so my fogs stay on with the high beams. I live out in the boonies, so all the light I can get, the better. As pictured in the webmaster's mod for fogs, bend the tab out on the RIGHT, not left, and run that wire to a grounding point, instead of a power point. I grounded it to the closest screw by the fusebox. If you decide that you don't want the fogs to flash when arming the alarm, bend the top tab of the relay and wire that to the key on power point, as mentioned in the webmaster's post. Thanks to the webmaster for his instructions. I was able to get a wiring diagram for the fogs from my job. My next thing I will try to figure out is how to totally disable traction control, as I try to drift corners, but traction keeps interfering with my fun!!! Good luck!! dave.....
