Hi, i am from Europe, Lithuania. I have is350 and want to change miles to km, maybe you can help me...
and can i somehow switch off tire pressure indicator? In winter time i ride with 17 inch rims without presure sensors...
Thanks,
Vytas
Thanks,
Vytas
You can switch off the tire pressure sensor with the switch that is to the left of the steering wheel (near the dash brightness knob). Scroll left or right until your dash reading says Tire Sensor. Then select off and it should do the trick.
For the miles to km, are you wanting to have it converted on the nav or are you talking about the odometer?
Hi, about odometer ...
I have tried to switch with that switch what you say but it doesn't switch off, there are written initialize sensors, no sensors off...
Thanks,
Vytas
