I've been thinking making a supercharger build on my is250 but i have no idea how much tq can the stock clutch and transmission handle. I would like to aim to somewhere between 210-230RWHP. Could the stock clutch and tranny handle that much and should i change any other internals?
The stock clutch will not be able to handle it and I would also switch the dual mass flywheel to a single mass because they are prone to failure. The transmission is fine as it is been in use in other larger cars with more torque. I'm not sure about the diff though.
2002 Lexus IS300
Tell you what you will be the first to know if it doesn’t hold 😅
