1 - 2 of 2 Posts
So I'm in the process of changing timing belt, valve cover gaskets, etc. I took off the throttlebody last night and noticed that when I turn the wheel on the side, the flap inside only opens about a quarter of the way, if that. How open should this be if it's basically at WOT? Should that flap be horizontal?
since our throttle bodies are electronically activated, that is about normal for the cable to only pull a quarter of the way.
1 - 2 of 2 Posts
