what do u mean by change them? change the bulb? change the lense? the whole housing?
to remove then...there are 2 10mm hex bolts in the hole next to them...you can feel them w/ your finger. take those out...
then open up your fender well by removing a few plastic screws, reach in and rotate the fog light itself 90 degrees, it'll pull right out (turning your wheels one way or the other would make this easier)...
after that...the foglight housings should pop right out through the front.
Look just inside your front fender wells ( turn the wheels out so you have more room / side you are working on ) Just inside the wheel well you will see a few plastic plugs that hold the black wheel liner in. Remove 2 or 3 of them. If the wheel is a clock face remove the top black plug(maybe 2 oclock) and the one or two below it. To remove them pop the small circle of the cap out with a flat head, then the whole plug thingie will pull out, do the same for the other plug(s). After that it's cake. Reach behind the wheel liner(where the plugs were removed). Turn the bulb plug that runs into the fog housing, pull out replace bulb. Screw bulb back into housing. Put wheel well plugs back in. Prolly take less then 15min, both sides. I looked for some pics of other install but couldnt find any. DOnt need em, its easy
