can the log manifolds only fit smaller sized turbos or can they fit larger ones too? whats the limit on how large it can fit without any clearance issues?
Correct. I had an SRT cast mani for many years. It is mounted on the underside. So, you have alot of room vs on top (fighting the brake lines and ABS block).Before he upgraded his setup....Redline814, had a t72 (GTQ housing) on a cast manifold.
